Seagate HDD Ext 10TB Expansion Desktop USB3
Quicklinx: GVM0WS00 Mfr#: STKP10000400
Form Factor: [N/A]
Capacity: 10TB
Interface: USB 3.0
16 In Stock
£301.83 ex VAT
£362.19 inc VAT
The Seagate Expansion desktop drive provides extra storage for your ever-growing collection of files. Instantly add space for more files, consolidate all of your files to a single location, or free up space on your computer's internal drive to help improve performance. Setup is straightforward; simply plug in the included power supply and USB cable, and you are ready to go. It is automatically recognized by the Windows or Mac operating system, so there is no software to install and nothing to configure. Saving files is easy too - just drag-and-drop. Take advantage of the fast data transfer speeds with the USB 3.0 interface by connecting to a USB 3.0 port.
  • Convenient external design
    The external form factor of the Seagate Expansion hard drive makes it easy to connect and disconnect, allowing for straightforward management of data storage without complicated setup.
  • Quick connectivity
    Equipped with a USB 3.0 interface, this hard drive offers faster data transfer speeds compared to previous USB standards, ensuring that transferring large files is efficient.
Seagate Expansion STKP10000400 - hard drive - 10 TB - USB 3.0
Hard drive - external (desktop)
10 TB
USB 3.0
Power Source
Included AC adapter
Enclosure Colour
41.9 mm x 178.75 mm x 125 mm
1.176 kg
Bundled with
Seagate Rescue Data Recovery
10 TB
USB 3.0
41.9 mm
178.75 mm
125 mm
1.176 kg
Bundled with
Expansion & Connectivity
1 x USB 3.0
Power Source
Included AC adapter
Windows 10 or later, Apple MacOS X 10.12 or later
1 x USB 3.0 cable - external - 45.72 cm
Enclosure Colour
Shipping Width
21.2 cm
Shipping Depth
21.8 cm
Shipping Height
7.7 cm
Shipping Weight
1.342 kg
Form Factor: [N/A]
Capacity: 10TB
Interface: USB 3.0
Brand: Seagate
