Nothing says "Game Over" for the PlayStation experience like a full hard drive. Expand your console's storage capacity and upgrade performance with the Seagate Game Drive for PlayStation 3 and PlayStation 4 - with zero compromise.
More capacity, more speed, zero compromise
The Game Drive combines NAND flash storage with a hard drive, giving you SSD-like performance and the immense capacity of an HDD. Replace your console's internal drive with the Game Drive for more action, less waiting. -
Keep all your (good) games
With 1TB on your PS3 or PS4, you can save the world - and all the games that are worth keeping. With space to store games - or a gigantic multimedia library - you won't have to delete games to make room for new ones. -
Pedal to the metal
Boot the system, load games faster, and spend less time watching progress bars. Adaptive Memory technology even improves performance over time as it learns your gaming behavior.
- Seagate Game Drive for PlayStation - hard drive - 5 TB - USB 3.2 Gen 1
- Hard drive - external (portable)
- Capacity
- 5 TB
- Interface
- USB 3.2 Gen 1
- Blue LED lighting
- Power Source
- USB bus
- Enclosure Colour
- White
- 8.1 mm x 12.25 mm x 2.15 mm
- 266 g
- Localisation
- EMEA
- 3-year warranty
- Capacity
- 5 TB
- Interface
- USB 3.2 Gen 1
- Blue LED lighting
- 8.1 mm
- 12.25 mm
- 2.15 mm
- 266 g
Expansion & Connectivity
- 1 x USB 3.2 Gen 1
- Power Source
- USB bus
- OS Required
- PlayStation 4 system software version 4.5 or later, PlayStation 5 system software version 21.01-03 or later
- Cables Included
- 1 x USB 3.0 cable - external - 46 cm
- Enclosure Colour
- White
- Localisation
- EMEA
- Shipping Width
- 10.6 cm
- Shipping Depth
- 14.9 cm
- Shipping Height
- 4.5 cm
- Shipping Weight
- 352 g
- Limited warranty - 3 years
