- Seagate Expansion Plus STEF2000401 - hard drive - 2 TB - USB 3.0
- Hard drive - external (portable)
- Capacity
- 2 TB
- Interface
- USB 3.0
- Data Transfer Rate
- 5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0)
- Power Source
- USB bus
- Enclosure Colour
- Black
- 80 mm x 14.8 mm x 117 mm
- 170 g
- Localisation
- EMEA
- 2-year warranty
- Capacity
- 2 TB
- Interface
- USB 3.0
- 80 mm
- 14.8 mm
- 117 mm
- 170 g
Performance
- Interface Transfer Rate
Expansion & Connectivity
- 1 x USB 3.0
- Power Source
- USB bus
- Software Included
- Seagate Dashboard
- OS Required
- Microsoft Windows 7 or later
- Cables Included
- 1 x USB 3.0 cable - 46 cm
- Enclosure Colour
- Black
- Localisation
- EMEA
- Limited warranty - 2 years
