Supporting the industry's best response times for an 8TB nearline drive, Seagate's Enterprise Capacity 3.5 HDD enables the fastest data transfers thanks to our comprehensive advanced caching technology. When building maximum density server and storage solutions with Seagate's Enterprise Capacity 3.5 HDD, you can rest easy knowing that your storage infrastructure can scale to meet your growing capacity needs while offering your users a consistent and predictable response rate.
Maximum capacity and built for speed
Supporting the industry's best response times for an 8TB nearline drive, Seagate's Seagate Exos 3.5 HDD enables the fastest data transfers thanks to our comprehensive advanced caching technology. -
World-class reliability meets high-capacity
When building maximum density server and storage solutions with Seagate's 8TB Seagate Exos 3.5 HDD, you can rest easy knowing that your storage infrastructure can scale to meet your growing capacity needs while offering your users a consistent and predictable response rate. -
Reliable, robust bulk data Storage for a 24 x 7 world
High capacity storage for multi-drive chassis requires predictable and reliable performance. The Seagate Exos 3.5 HDD is built to support enterprise-class nearline workloads of up 550TB per year, which is up to 10x the rated workload of desktop HDDs. Clearly, the Seagate Exos 3.5 HDD can help to ensure that you meet your rigorous bulk storage SLAs.
- Seagate Exos 7E8 ST6000NM0095 - hard drive - 6 TB - SAS 12Gb/s
- Hard drive - internal
- Capacity
- 6 TB
- Form Factor
- 3.5" x 1/3H
- Interface
- SAS 12Gb/s
- Data Transfer Rate
- 1.2 GBps
- Buffer Size
- 256 MB
- Spindle Speed
- 7200 rpm
- Halogen Free, Ramp Load, dual processor, PowerChoice, Humidity Sensor, Super Parity, T10 Data Integrity Field (DIF), advanced format 512e, 24x7 availability, Advanced Write Caching
- 101.85 mm x 147 mm x 26.1 mm
- 705 g
- 5-year warranty
- Capacity
- 6 TB
- Form Factor
- 3.5" x 1/3H
- Interface
- SAS 12Gb/s
- Buffer Size
- 256 MB
- 101.85 mm
- 147 mm
- 26.1 mm
- 705 g
Performance
- Drive Transfer Rate
- 1.2 GBps (external)
- Internal Data Rate
- 226 MBps
- Average Latency
- 4.16 ms
- Spindle Speed
- 7200 rpm
Reliability
- MTBF
- 2,000,000 hours
- 24x7 Operation
- Non-Recoverable Errors
- 1 per 10^15
Expansion & Connectivity
- 2 x SAS 12 Gb/s
- Compatible Bay
- 3.5" x 1/3H
- Power Consumption
- 8.37 Watt (idle) , 9.2 Watt (active)
- Software Included
- Seagate SeaTools
- Limited warranty - 5 years
- 5 °C
- 60 °C
- Shock Tolerance (operating)
- 40 g @ 2 ms
- Shock Tolerance (non-operating)
- 250 g @ 1 ms
