The Savvio 15K.3 drive enables Tier 1 applications to read and write both random and sequential data faster. Data centers can store and access important random data up to 10% faster and sequential data up to 21% faster over previous generations, enabling them to process more transactions within a given time period.
Providing up to 300 GB capacity, the Seagate Savvio 15K.3 drive stores twice the amount of data without increasing the total number hard drives used. This helps data centers keep up with the growth of data while improving storage efficiency.
The Savvio 15K.3 drive provides protection information and self-encrypting drive options to help companies achieve corporate and/or government security compliance goals. The drive helps protect data from inadvertent change from the moment of creation until the end of life, and from exposure if the device is lost, stolen or retired.
Enhanced durability
Built to withstand continuous operation in demanding environments, the Seagate Exos 15E900 is equipped with a humidity sensor and advanced vibration tolerance, ensuring reliable performance under varying conditions. -
High-speed performance
With a spindle speed of 15,000 rpm and an internal data rate of 315 MBps, complemented by Seagate TurboBoost and Advanced Write Caching, this hard drive delivers swift and efficient data access and transfer. -
Energy-efficient operation
Featuring Power Choice Idle Power technology, the Seagate Exos 15E900 optimizes power consumption during idle periods, reducing energy costs while maintaining readiness for active operations. -
Robust storage capacity
Offering a 600 GB capacity with dual port and hot-plug support, this hard drive is designed for seamless integration and expansion in high-capacity storage systems, ensuring ample space for critical data.
- Seagate Exos 15E900 ST600MP0136 - hard drive - 600 GB - SAS 12Gb/s
- Hard drive - internal
- Capacity
- 600 GB
- Form Factor
- 2.5" SFF
- Interface
- SAS 12Gb/s
- Data Transfer Rate
- 2400 MBps
- Buffer Size
- 256 MB
- Spindle Speed
- 15000 rpm
- Dual Port, Humidity Sensor, Low Halogen, Hot-Plug Support, Seagate TurboBoost, advanced format 512e, advanced format 4Kn, 24x7 availability, Power Choice Idle Power technology, Organic Solderability Preservative, Advanced Write Caching, Intelligent NAND Endurance Management, Seagate Fast Format
- 69.85 mm x 100.45 mm x 15 mm
- 230 g
- 5-year warranty
- Capacity
- 600 GB
- Form Factor
- 2.5" SFF
- Interface
- SAS 12Gb/s
- Buffer Size
- 256 MB
- 69.85 mm
- 100.45 mm
- 15 mm
- 230 g
Performance
- Drive Transfer Rate
- 2400 MBps (external)
- Internal Data Rate
- 315 MBps
- Average Latency
- 2 ms
- Spindle Speed
- 15000 rpm
Reliability
- 24x7 Operation
- Non-Recoverable Errors
- 1 per 10^16
Expansion & Connectivity
- 2 x SAS 12 Gb/s
- Compatible Bay
- 2.5" SFF
- Power Consumption
- 5.8 Watt (idle) , 7.2 Watt (active)
- Limited warranty - 5 years
- 5 °C
- 55 °C
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- 5 - 95% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 11 ms
- Shock Tolerance (non-operating)
- 400 g @ 2 ms
- Vibration Tolerance (operating)
- 0.5 g @ 0-400 Hz
- Vibration Tolerance (non-operating)
- 2.4 g @ 0-500 Hz
