Seagate Exos 600GB E-Class Mission Critical SAS 2.5" 10K 512
Quicklinx: DDWJWS00 Mfr#: ST600MM0099
Hurry, only 1 left in stock!
£119.77 ex VAT
£143.72 inc VAT
The Seagate Enterprise Performance 10K HDD is an ideal 1.2 TB hard drive for mission critical applications. It delivers best-in-class mission critical random performance, highest capacities and the low power that data centers need to meet demanding service level agreements and to keep up with data growth and reduce IT operating costs.
  • The perfect match of high capacity and high performance
    The high capacity and small 2.5-inch footprint of the Exos 10E2400 drive enables data centers to keep pace with data growth and optimize data center real estate. A single advanced format interface model lets you future-proof your storage infrastructure. The Seagate Enhanced Caching feature accelerates read and write I/O operations, preventing applications from slowing down under peak usage conditions. The 12Gb/s SAS interface provides improved scalability.
  • Maximize storage investments for the long haul
    Exos 10E2400 offers Protection Information (PI) to help protect against data corruption, and Seagate PowerChoice technology for T10-compliant power management enables IT organizations to tailor systems for enhanced power consumption. RAID recovery is faster and safer with the help of the Seagate RAID Rebuild technology option.
  • Data security features
    Seagate Secure SED and FIPS 140-2 government-grade models offer hardware-based security to help protect data-at-rest. With Instant Secure Erase, drive retirement is safe, fast and cost-effective. Seagate Secure models meet the NIST 800-88 media sanitization specification and support the Trusted Computer Group (TCG) standard.
Seagate Exos 10E2400 ST600MM0099 - Generation 10K.9 - hybrid hard drive - 600 GB - SAS 12Gb/s
Hybrid hard drive - internal
600 GB
Flash Memory Capacity
16 GB
NAND Flash Memory Type
Enterprise multi-level cell (eMLC)
2.5" SFF
SAS 12Gb/s
Data Transfer Rate
1.2 GBps
Buffer Size
256 MB
Spindle Speed
10000 rpm
Protection Information (PI), Seagate Instant Secure Erase (ISE), Seagate RAID Rebuild, Seagate TurboBoost, Intelligent NAND Endurance Management, Seagate Fast Format, Secure Download & Diagnostics (SD&D)
70.1 mm x 100.45 mm x 15 mm
225 g
5-year warranty
600 GB
16 GB
2.5" SFF
SAS 12Gb/s
Buffer Size
256 MB
70.1 mm
100.45 mm
15 mm
225 g
Performance
Drive Transfer Rate
1.2 GBps (external)
Internal Data Rate
270 MBps
Average Latency
2.9 ms
Spindle Speed
10000 rpm
Reliability
Non-Recoverable Errors
1 per 10^16
Expansion & Connectivity
1 x SAS 12 Gb/s
Compatible Bay
2.5" SFF
Power Consumption
7 watt (active) , 3.8 watt (idle)
Limited warranty - 5 years
5 °C
55 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Shock Tolerance (operating)
40 g @ 11 ms
Shock Tolerance (non-operating)
400 g @ 2 ms
Vibration Tolerance (operating)
0.5 g @ 0-500 Hz
Vibration Tolerance (non-operating)
3 g @ 0-500 Hz
Type: Hybrid hard drive
Brand: Seagate
