Seagate Exos 300GB E-Class Mission Critical 15000 RPM 2.5" 256GB Hard Drive
Quicklinx: D76FWS00 Mfr#: ST300MP0106
Form Factor: 2.5" SFF
Type: Hard drive
Interface Type: SAS
Capacity: 300GB
Spin Speed (rpm): 15000rpm
Hurry, only 3 left in stock!
£133.92 ex VAT
£160.70 inc VAT
The Savvio 15K.3 drive enables Tier 1 applications to read and write both random and sequential data faster. Data centers can store and access important random data up to 10% faster and sequential data up to 21% faster over previous generations, enabling them to process more transactions within a given time period.
Providing up to 300 GB capacity, the Seagate Savvio 15K.3 drive stores twice the amount of data without increasing the total number hard drives used. This helps data centers keep up with the growth of data while improving storage efficiency.
The Savvio 15K.3 drive provides protection information and self-encrypting drive options to help companies achieve corporate and/or government security compliance goals. The drive helps protect data from inadvertent change from the moment of creation until the end of life, and from exposure if the device is lost, stolen or retired.
  • Improves performance
  • Doubles capacity
  • Protects data
Seagate Exos 15E900 ST300MP0106 - hard drive - 300 GB - SAS 12Gb/s
Hard drive - internal
300 GB
2.5" SFF
SAS 12Gb/s
Data Transfer Rate
2400 MBps
Buffer Size
256 MB
Spindle Speed
15000 rpm
Dual Port, Humidity Sensor, Low Halogen, Hot-Plug Support, Seagate TurboBoost, advanced format 512e, advanced format 4Kn, 24x7 availability, Power Choice Idle Power technology, Organic Solderability Preservative, Advanced Write Caching, Intelligent NAND Endurance Management, Seagate Fast Format
69.85 mm x 100.45 mm x 15 mm
225 g
5-year warranty
300 GB
2.5" SFF
SAS 12Gb/s
Buffer Size
256 MB
69.85 mm
100.45 mm
15 mm
225 g
Performance
Drive Transfer Rate
2400 MBps (external)
Internal Data Rate
315 MBps
Average Latency
2 ms
Spindle Speed
15000 rpm
Reliability
24x7 Operation
Non-Recoverable Errors
1 per 10^16
Expansion & Connectivity
2 x SAS 12 Gb/s
Compatible Bay
2.5" SFF
Power Consumption
4.7 Watt (idle) , 6.9 Watt (active)
Limited warranty - 5 years
5 °C
55 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
5 - 95% (non-condensing)
Shock Tolerance (operating)
40 g @ 11 ms
Shock Tolerance (non-operating)
400 g @ 2 ms
Vibration Tolerance (operating)
0.5 g @ 0-400 Hz
Vibration Tolerance (non-operating)
2.4 g @ 0-500 Hz
Type: Hard drive
Interface Type: SAS
Capacity: 300GB
Brand: Seagate
Stock Status: In stock
