Seagate Exos 2TB E-Class Nearline Enterprise 7200RPM 3.5" 128MB Hard Drive
Quicklinx: D73FWS00 Mfr#: ST2000NM0008
Supporting the industry's best response times for an 8TB a nearline drive, the Seagate Enterprise Capacity 3.5 HDD enables the fastest data transfers thanks to our comprehensive advanced caching technology.Meet your storage workload requirements in the most efficient and cost-effective data center footprint available on the market. With innovative technology advancements like PowerBalance, PowerChoice and RAID Rebuild, you can customize your bulk storage requirements for even greater improvements in your TCO.
When building maximum density server and storage solutions with the 8TB Enterprise Capacity 3.5 HDD, you can rest easy knowing that your storage infrastructure can scale to meet your growing capacity needs, while offering your users a consistent and predictable response rate. Built to support enterprise-class nearline workloads of 550TB/yr, and backed by 2M hours MTBF as well as a 5-Year Limited Warranty, the Enterprise Capacity 3.5 HDD helps to ensure you can meet all of your bulk storage SLAs.
High capacity storage for multi-drive chassis requires predictable and reliable performance. The Enterprise Capacity 3.5 HDD is built to support enterprise-class nearline workloads of up 550 TB per year, which is up to 10x the rated workload of desktop HDDs. Clearly, the Enterprise Capacity 3.5 HDD can help to ensure that you meet your rigorous bulk storage SLAs. Choose from 12 Gb/s SAS or SATA 6 Gb/s interfaces for easy integration into existing platforms.
  • Impressive capacity - designed for speed
  • World-class reliability meets high-capacity
  • Reliable, robust bulk data storage for a 24 x 7 world
Seagate Exos 7E2 ST2000NM0008 - hard drive - 2 TB - SATA 6Gb/s
Hard drive - internal
2 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
128 MB
Spindle Speed
7200 rpm
PowerChoice, Seagate RAID Rebuild, 24x7 continuous operation, Low Halogen, Super Parity
101.6 mm x 147 mm x 26.1 mm
550 g
5-year warranty
2 TB
3.5"
SATA 6Gb/s
Buffer Size
128 MB
Bytes per Sector
512
101.6 mm
147 mm
26.1 mm
550 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
194 MBps
Average Latency
4.16 ms
Spindle Speed
7200 rpm
Reliability
MTBF
2,000,000 hours
24x7 Operation
Non-Recoverable Errors
1 per 10^15
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
Power Consumption
4.7 Watt (idle) , 7 Watt (active)
Software Included
Seagate SeaTools
Limited warranty - 5 years
5 °C
60 °C
Shock Tolerance (operating)
70 g @ 2 ms
Shock Tolerance (non-operating)
300 g @ 2 ms
Vibration Tolerance (non-operating)
5 g @ 10-500 Hz
