Seagate Exos 2TB E-Class Nearline Enterprise 7200RPM 2.5" 128MB Hard Drive
Quicklinx: D74FWS00 Mfr#: ST2000NX0253
The Seagate Enterprise Capacity 2.5 HDD is the only 2.5-inch enterprise-class hard drive delivering high capacities and enterprise reliability at the industry's lowest power per watt for storage-hungry nearline applications.
The Enterprise Capacity 2.5 HDDs reduce per-gigabyte cooling and energy costs by packing high capacities into an SFF, low-power-consumption drive.
The Enterprise Capacity 2.5 HDDs can help you deploy additional enterprise storage without expanding your data center.
  • Enhanced durability
    With a mean time between failures (MTBF) of 1,400,000 hours, the Seagate Exos 7E2000 is built to last, ensuring reliability and durability for continuous operation in demanding environments.
  • Efficient power management
    Features such as Low Halogen and PowerChoice technology provide an eco-friendly solution by significantly reducing power consumption during idle, read, and standby modes, making it an energy-efficient choice for data centers.
  • High-speed performance
    Equipped with a Serial ATA-600 interface, the drive offers a fast data transfer rate of up to 600 MBps, coupled with a 7200 rpm spindle speed, to deliver quick access to data and efficient performance in high-load situations.
  • Secure data storage
    The Secure Drive feature enhances data security, offering peace of mind by protecting stored information against unauthorized access, making it suitable for sensitive data storage requirements.
  • Optimized for compatibility
    Designed to be compatible with Windows 7 and a wide range of PC configurations, this internal hard drive integrates seamlessly into existing systems, ensuring a smooth and reliable storage solution.
Seagate Exos 7E2000 ST2000NX0253 - hard drive - 2 TB - SATA 6Gb/s
Hard drive - internal - nearline
2 TB
2.5" SFF
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
128 MB
Spindle Speed
7200 rpm
PowerChoice, Secure Drive, Seagate RAID Rebuild, Low Halogen
70.1 mm x 100.45 mm x 15 mm
198 g
Microsoft Certification
Compatible with Windows 7
5-year warranty
2 TB
2.5" SFF
SATA 6Gb/s
Buffer Size
128 MB
Bytes per Sector
512
70.1 mm
100.45 mm
15 mm
198 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
136 MBps
Average Latency
4.16 ms
Spindle Speed
7200 rpm
Reliability
MTBF
1,400,000 hours
Non-Recoverable Errors
1 per 10^15
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
2.5" SFF
Power Consumption
3.87 watt (idle) , 5.22 watt (read) , 1.14 watt (standby)
Limited warranty - 5 years
5 °C
55 °C
Shock Tolerance (operating)
25 g @ 2 ms
Shock Tolerance (non-operating)
400 g @ 2 ms
Vibration Tolerance (operating)
0.5 g @ 5-500 Hz
Vibration Tolerance (non-operating)
3 g @ 5-500 Hz
