Supporting the industry's best response times for an 8TB a nearline drive, the Seagate Enterprise Capacity 3.5 HDD enables the fastest data transfers thanks to our comprehensive advanced caching technology.Meet your storage workload requirements in the most efficient and cost-effective data center footprint available on the market. With innovative technology advancements like PowerBalance, PowerChoice and RAID Rebuild, you can customize your bulk storage requirements for even greater improvements in your TCO.
When building maximum density server and storage solutions with the 8TB Enterprise Capacity 3.5 HDD, you can rest easy knowing that your storage infrastructure can scale to meet your growing capacity needs, while offering your users a consistent and predictable response rate. Built to support enterprise-class nearline workloads of 550TB/yr, and backed by 2M hours MTBF as well as a 5-Year Limited Warranty, the Enterprise Capacity 3.5 HDD helps to ensure you can meet all of your bulk storage SLAs.
High capacity storage for multi-drive chassis requires predictable and reliable performance. The Enterprise Capacity 3.5 HDD is built to support enterprise-class nearline workloads of up 550 TB per year, which is up to 10x the rated workload of desktop HDDs. Clearly, the Enterprise Capacity 3.5 HDD can help to ensure that you meet your rigorous bulk storage SLAs. Choose from 12 Gb/s SAS or SATA 6 Gb/s interfaces for easy integration into existing platforms.
Enhanced durability
Designed for continuous operation and equipped with Seagate RAID Rebuild technology, the Seagate Exos 7E2 ensures reliable access to your data when you need it most. Its robust design is further supported by a shock acceleration operating tolerance of 70 g and a non-operating tolerance of 300 g, making it a resilient choice for demanding environments. -
Energy efficient
With PowerChoice technology, the Seagate Exos 7E2 optimizes power consumption during idle and active modes, consuming only 4.7 W in idle and 7 W during active operations. This not only reduces operational costs but also supports a more sustainable environment. -
High performance
Boasting a spindle speed of 7200 rpm and an internal data rate of 194 MBps, coupled with a data transfer rate of 600 MBps, this hard drive delivers fast and efficient performance for your computing needs. Its 1 TB capacity and 512 bytes per sector provide ample space and efficient storage for your data.
- Seagate Exos 7E2 ST1000NM0008 - hard drive - 1 TB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 1 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 128 MB
- Spindle Speed
- 7200 rpm
- PowerChoice, Seagate RAID Rebuild, 24x7 continuous operation, Low Halogen, Super Parity
- 101.6 mm x 147 mm x 26.1 mm
- 550 g
- 5-year warranty
- Capacity
- 1 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Buffer Size
- 128 MB
- Bytes per Sector
- 512
- 101.6 mm
- 147 mm
- 26.1 mm
- 550 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 194 MBps
- Average Latency
- 4.16 ms
- Spindle Speed
- 7200 rpm
Reliability
- MTBF
- 2,000,000 hours
- 24x7 Operation
- Non-Recoverable Errors
- 1 per 10^15
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 3.5"
- Power Consumption
- 4.7 Watt (idle) , 7 Watt (active)
- Software Included
- Seagate SeaTools
- Limited warranty - 5 years
- 5 °C
- 60 °C
- Shock Tolerance (operating)
- 70 g @ 2 ms
- Shock Tolerance (non-operating)
- 300 g @ 2 ms
- Vibration Tolerance (non-operating)
- 5 g @ 10-500 Hz
