The Seagate Enterprise Performance 10K HDD is an ideal 1.2 TB hard drive for mission critical applications. It delivers best-in-class mission critical random performance, highest capacities and the low power that data centers need to meet demanding service level agreements and to keep up with data growth and reduce IT operating costs.
Maximize storage investments for the long haul
Exos 10E2400 offers protection information to help protect against data corruption. RAID recovery is faster and safer. -
Superior data security features
With instant secure erase, drive retirement is safe, fast and cost effective.
 - Seagate Exos 10E2400 ST1200MM0009 - hard drive - 1.2 TB - SAS 12Gb/s
 - Hard drive - internal
- Capacity
 - 1.2 TB
- Form Factor
 - 2.5" SFF
- Interface
 - SAS 12Gb/s
- Data Transfer Rate
 - 1.2 GBps
- Buffer Size
 - 128 MB
- Spindle Speed
 - 10000 rpm
 - PowerChoice, Protection Information (PI), Seagate RAID Rebuild, Instant Secure Erase (ISE), advanced format 512n, Seagate Fast Format
 - 70.1 mm x 100.45 mm x 15 mm
 - 193 g
 - 5-year warranty
- Capacity
 - 1.2 TB
- Form Factor
 - 2.5" SFF
- Interface
 - SAS 12Gb/s
- Buffer Size
 - 128 MB
- Bytes per Sector
 - 512
 - 70.1 mm
 - 100.45 mm
 - 15 mm
 - 193 g
Performance
- Drive Transfer Rate
 - 1.2 GBps (external)
- Internal Data Rate
 - 250 MBps
- Average Latency
 - 2.9 ms
- Spindle Speed
 - 10000 rpm
Reliability
- Non-Recoverable Errors
 - 1 per 10^16
Expansion & Connectivity
 - 1 x SAS 12 Gb/s
- Compatible Bay
 - 2.5" SFF
- Power Consumption
 - 7.25 Watt (active) , 4.26 Watt (idle)
 - Limited warranty - 5 years
 - 5 °C
 - 55 °C
- Min Storage Temperature
 - -40 °C
- Max Storage Temperature
 - 70 °C
- Shock Tolerance (operating)
 - 40 g @ 11 ms
- Shock Tolerance (non-operating)
 - 400 g @ 2 ms
- Vibration Tolerance (operating)
 - 0.5 g @ 0-500 Hz
- Vibration Tolerance (non-operating)
 - 3 g @ 0-500 Hz
