Seagate Exos 1.2TB E-Class Mission Critical 10000RPM 2.5" 128MB Hard Drive
Quicklinx: D74NWS00 Mfr#: ST1200MM0009
Form Factor: 2.5 SFF
Type: Hard drive
Interface Type: SAS
Capacity: 1.2TB
Spin Speed (rpm): 10000rpm
15 In Stock
£187.23 ex VAT
£224.67 inc VAT
The Seagate Enterprise Performance 10K HDD is an ideal 1.2 TB hard drive for mission critical applications. It delivers best-in-class mission critical random performance, highest capacities and the low power that data centers need to meet demanding service level agreements and to keep up with data growth and reduce IT operating costs.
  • Maximize storage investments for the long haul
    Exos 10E2400 offers protection information to help protect against data corruption. RAID recovery is faster and safer.
  • Superior data security features
    With instant secure erase, drive retirement is safe, fast and cost effective.
Seagate Exos 10E2400 ST1200MM0009 - hard drive - 1.2 TB - SAS 12Gb/s
Hard drive - internal
1.2 TB
2.5" SFF
SAS 12Gb/s
Data Transfer Rate
1.2 GBps
Buffer Size
128 MB
Spindle Speed
10000 rpm
PowerChoice, Protection Information (PI), Seagate RAID Rebuild, Instant Secure Erase (ISE), advanced format 512n, Seagate Fast Format
70.1 mm x 100.45 mm x 15 mm
193 g
5-year warranty
1.2 TB
2.5" SFF
SAS 12Gb/s
Buffer Size
128 MB
Bytes per Sector
512
70.1 mm
100.45 mm
15 mm
193 g
Performance
Drive Transfer Rate
1.2 GBps (external)
Internal Data Rate
250 MBps
Average Latency
2.9 ms
Spindle Speed
10000 rpm
Reliability
Non-Recoverable Errors
1 per 10^16
Expansion & Connectivity
1 x SAS 12 Gb/s
Compatible Bay
2.5" SFF
Power Consumption
7.25 Watt (active) , 4.26 Watt (idle)
Limited warranty - 5 years
5 °C
55 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Shock Tolerance (operating)
40 g @ 11 ms
Shock Tolerance (non-operating)
400 g @ 2 ms
Vibration Tolerance (operating)
0.5 g @ 0-500 Hz
Vibration Tolerance (non-operating)
3 g @ 0-500 Hz
Type: Hard drive
Interface Type: SAS
Capacity: 1.2TB
Brand: Seagate
