Seagate Enterprise Capacity 3TB V.5 Hard Drive 3.5" SAS 12Gb/s
Quicklinx: CP75WS00 Mfr#: ST3000NM0025
Supporting the industry's best response times for an 8TB nearline drive, Seagate's Enterprise Capacity 3.5 HDD enables the fastest data transfers thanks to our comprehensive advanced caching technology. When building maximum density server and storage solutions with Seagate's Enterprise Capacity 3.5 HDD, you can rest easy knowing that your storage infrastructure can scale to meet your growing capacity needs while offering your users a consistent and predictable response rate.
  • Maximum capacity and built for speed
    Supporting the industry's best response times for an 8TB nearline drive, Seagate's Seagate Exos 3.5 HDD enables the fastest data transfers thanks to our comprehensive advanced caching technology.
  • World-class reliability meets high-capacity
    When building maximum density server and storage solutions with Seagate's 8TB Seagate Exos 3.5 HDD, you can rest easy knowing that your storage infrastructure can scale to meet your growing capacity needs while offering your users a consistent and predictable response rate.
  • Reliable, robust bulk data Storage for a 24 x 7 world
    High capacity storage for multi-drive chassis requires predictable and reliable performance. The Seagate Exos 3.5 HDD is built to support enterprise-class nearline workloads of up 550TB per year, which is up to 10x the rated workload of desktop HDDs. Clearly, the Seagate Exos 3.5 HDD can help to ensure that you meet your rigorous bulk storage SLAs.
Seagate Exos 7E8 ST3000NM0025 - hard drive - 3 TB - SAS 12Gb/s
Hard drive - internal
3 TB
3.5" x 1/3H
SAS 12Gb/s
Data Transfer Rate
1.2 GBps
Buffer Size
128 MB
Spindle Speed
7200 rpm
Halogen Free, Ramp Load, dual processor, PowerChoice, Humidity Sensor, Super Parity, T10 Data Integrity Field (DIF), 24x7 availability, advanced format 512n
101.85 mm x 147 mm x 26.1 mm
680 g
5-year warranty
3 TB
3.5" x 1/3H
SAS 12Gb/s
Buffer Size
128 MB
Bytes per Sector
512
101.85 mm
147 mm
26.1 mm
680 g
Performance
Drive Transfer Rate
1.2 GBps (external)
Internal Data Rate
215 MBps
Average Latency
4.16 ms
Spindle Speed
7200 rpm
Reliability
MTBF
2,000,000 hours
24x7 Operation
Non-Recoverable Errors
1 per 10^15
Expansion & Connectivity
2 x SAS 12 Gb/s
Compatible Bay
3.5" x 1/3H
Power Consumption
6.52 watt (idle) , 7.74 watt (active)
Software Included
Seagate SeaTools
Limited warranty - 5 years
5 °C
60 °C
Shock Tolerance (operating)
40 g @ 2 ms
Shock Tolerance (non-operating)
250 g @ 1 ms
