Seagate Barracuda Pro ST500LM034 Internal Hard drive, 500 GB, SATA 6Gb/s, 7200 rpm, buffer: 128 MB
                Robust performanceWith an average latency of 11.5 ms and a spindle speed of 7200 rpm, this internal hard drive delivers reliable and consistent performance for demanding applications.
                High capacity storageOffering a generous 500 GB capacity, this hard drive provides ample space for your documents, photos, and videos, making it an ideal solution for both personal and professional use.
                Durable designEngineered to withstand operational environments ranging from 5 - 90% humidity and operating temperatures from 0°C to 60°C, ensuring reliability and longevity in a variety of conditions.
- Seagate Barracuda Pro ST500LM034 - hard drive - 500 GB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 500 GB
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 128 MB
- Spindle Speed
- 7200 rpm
- S.M.A.R.T.
- 100.35 mm x 69.85 mm x 7 mm
- 90 g
- Capacity
- 500 GB
- Interface
- SATA 6Gb/s
- Buffer Size
- 128 MB
- S.M.A.R.T.
- 100.35 mm
- 69.85 mm
- 7 mm
- 90 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 160 MBps
- Average Latency
- 11.5 ms
- Spindle Speed
- 7200 rpm
Reliability
- Non-Recoverable Errors
- 1 per 10^14
- Load / Unload Cycles
- 600,000
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- BSMI, ICES-003, UL 60950-1, EN 60950-1, KC, cUL No.60950-1, China RoHS, RCM, RoHS 2011/65/EU, SVHC, FCC Part 15 J Class B, EN 55024:2010, RoHS 2 (2011/65/EU), EN 55032:2012, Directive 2014/30/EU, Directive 2015/863
- 0 °C
- 60 °C
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- 5 - 90%
