- Seagate Barracuda Pro ST1000LM049 - hard drive - 1 TB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 1 TB
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 128 MB
- Spindle Speed
- 7200 rpm
- S.M.A.R.T.
- 100.35 mm x 69.85 mm x 7 mm
- 90 g
- Capacity
- 1 TB
- Interface
- SATA 6Gb/s
- Buffer Size
- 128 MB
- S.M.A.R.T.
- 100.35 mm
- 69.85 mm
- 7 mm
- 90 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 160 MBps
- Average Latency
- 11.5 ms
- Spindle Speed
- 7200 rpm
Reliability
- Non-Recoverable Errors
- 1 per 10^14
- Load / Unload Cycles
- 600,000
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- BSMI, ICES-003, UL 60950-1, EN 60950-1, KC, cUL No.60950-1, China RoHS, RCM, RoHS 2011/65/EU, SVHC, FCC Part 15 J Class B, EN 55024:2010, RoHS 2 (2011/65/EU), EN 55032:2012, Directive 2014/30/EU, Directive 2015/863
- 0 °C
- 60 °C
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- 5 - 90%
