Industry's first high-capacity hard drive is designed for cost-effectively storing active archive data and cloud content.
Lowest cost/TB online data archive solution for petabytes of growing archival storage helps to ensure affordable long-term data management. SMR-enabled technology ensures efficient and economical cold storage operations even in the harshest data center environments.
The Archive HDD is optimized for cold data storage with the lowest power consumption and the on-demand, time-to-ready PowerChoice feature.
Affordable active Archive hard drives for cloud storage
Industry's first high-capacity hard drive is designed for cost-effectively storing active archive data and cloud content. -
Cost-effective high capacity
Lowest cost/TB online data archive solution for petabytes of growing archival storage helps to ensure affordable long-term data management. SMR-enabled technology ensures efficient and economical cold storage operations even in the harshest data center environments. -
Energy-efficient high-density cloud hard drive
- Seagate Archive HDD ST8000AS0002 - hard drive - 8 TB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 8 TB
- Form Factor
- 3.5" x 1/3H
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 128 MB
- Native Command Queuing (NCQ), Halogen Free, Advanced Format technology, PowerChoice, Seagate AcuTrac technology, S.M.A.R.T.
- 101.6 mm x 146.99 mm x 26.11 mm
- 780 g
- 3-year warranty
- Capacity
- 8 TB
- Form Factor
- 3.5" x 1/3H
- Interface
- SATA 6Gb/s
- Buffer Size
- 128 MB
- Bytes per Sector
- 4096
- 101.6 mm
- 146.99 mm
- 26.11 mm
- 780 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 190 MBps (read) / 150 MBps (write)
Reliability
- MTBF
- 800,000 hours
- Non-Recoverable Errors
- 1 per 10^14
- Load / Unload Cycles
- 300,000
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 3.5" x 1/3H
- Power Consumption
- 7.5 watt (active) , 5 watt (idle) , 1 watt (standby) , 1 watt (sleep)
- Software Included
- Seagate SeaTools
- RoHS
- Limited warranty - 3 years
- 0 °C
- 60 °C
