Seagate Archive Hard drive 8TB Internal 3.5" SATA 6Gb/s
Quicklinx: B35TWS00 Mfr#: ST8000AS0002
Industry's first high-capacity hard drive is designed for cost-effectively storing active archive data and cloud content.
Lowest cost/TB online data archive solution for petabytes of growing archival storage helps to ensure affordable long-term data management. SMR-enabled technology ensures efficient and economical cold storage operations even in the harshest data center environments.
The Archive HDD is optimized for cold data storage with the lowest power consumption and the on-demand, time-to-ready PowerChoice feature.
  • Affordable active Archive hard drives for cloud storage
  • Cost-effective high capacity
  • Energy-efficient high-density cloud hard drive
Seagate Archive HDD ST8000AS0002 - hard drive - 8 TB - SATA 6Gb/s
Hard drive - internal
8 TB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
128 MB
Native Command Queuing (NCQ), Halogen Free, Advanced Format technology, PowerChoice, Seagate AcuTrac technology, S.M.A.R.T.
101.6 mm x 146.99 mm x 26.11 mm
780 g
3-year warranty
8 TB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
128 MB
Bytes per Sector
4096
101.6 mm
146.99 mm
26.11 mm
780 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
190 MBps (read) / 150 MBps (write)
Reliability
MTBF
800,000 hours
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5" x 1/3H
Power Consumption
7.5 watt (active) , 5 watt (idle) , 1 watt (standby) , 1 watt (sleep)
Software Included
Seagate SeaTools
RoHS
Limited warranty - 3 years
60 °C
