Seagate 8TB SkyHawk 3.5" SATA 6Gb/s 256MB Surveillance Hard Drive
Quicklinx: CH00WS00 Mfr#: ST8000VX0022
Smart. Safe. Secure. Seagate provides drives specifically for surveillance storage for years. SkyHawk is built to keep systems in the field longer and reduce the need for post-deployment support.
  • Reliable performance
    Designed for continuous operation, the Seagate SkyHawk Surveillance HDD ensures constant availability and reliability for your surveillance system, backed by a high MTBF of 1,000,000 hours for long-term dependability.
  • High capacity storage
    With an 8 TB capacity, this hard drive provides ample space for storing large volumes of data, making it ideal for surveillance footage and high-resolution video storage needs.
  • Efficient operation
    The Seagate SkyHawk features advanced power management with a low power consumption of 9 W during active mode and as little as 0.6 W during sleep and standby modes, ensuring energy-efficient operation.
  • Enhanced data integrity
    Equipped with RV Sensor technology, the hard drive minimizes the risk of data loss due to vibration, offering more stable performance in multi-drive systems.
  • Fast data transfer
    A data transfer rate of 600 MBps and a spindle speed of 7200 rpm enable quick access to stored data, enhancing the efficiency of data retrieval and storage processes.
Seagate SkyHawk Surveillance HDD ST8000VX0022 - hard drive - 8 TB - SATA 6Gb/s
Hard drive - internal
8 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
256 MB
Spindle Speed
7200 rpm
RV Sensor, 24x7 availability
101.85 mm x 146.99 mm x 26.11 mm
780 g
3-year warranty
8 TB
3.5"
SATA 6Gb/s
Buffer Size
256 MB
101.85 mm
146.99 mm
26.11 mm
780 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
210 MBps
Spindle Speed
7200 rpm
Reliability
MTBF
1,000,000 hours
24x7 Operation
Non-Recoverable Errors
1 per 10^15
Load / Unload Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5"
Power Consumption
2 watt (start) , 9 watt (active) , 7.6 watt (idle) , 0.6 watt (sleep) , 0.6 watt (standby)
Limited warranty - 3 years
5 °C
70 °C
