IronWolf Pro is designed for everything business NAS. Get used to tough, ready and scalable 24 x 7 performance that can handle multi-drive environments.
Optimized for NAS with AgileArray
AgileArray is built for dual-plane balancing and RAID optimization in multi-bay environments with the most advanced power management possible. -
High performance means reduced lag times
High performance means reduced lag times or downtime for users during high traffic time for the NAS. Seagate leads the competition with the highest performance in NAS-class drives. -
Seagate rescue data recovery
IronWolf Pro comes with extra peace of mind for any mechanical, accidental or natural disaster. With a 90% success rate of in-house recovery, Seagate has your back with a rescue data recovery plan. -
Rotational Vibration (RV) mitigation
IronWolf Pro comes standard with RV sensors to maintain high performance in multi-bay NAS enclosures. -
Do more with multi-user technology
Enables user workload rate. Multiple users can confidently upload and download data to the NAS server, knowing it can handle the workload, whether you're a creative professional or small business. -
Designed for always on, always accessible 24 x 7 performance
Access your data on your NAS any time, remotely or on site.
- Seagate IronWolf Pro ST8000NE0004 - hard drive - 8 TB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 8 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 256 MB
- Spindle Speed
- 7200 rpm
- Hot-Plug Support, advanced format 512e, 24x7 availability, rotation vibration sensor, AgileArray
- 101.85 mm x 146.99 mm x 26.11 mm
- 650 g
- 5-year warranty
- Bundled with
- Seagate Rescue Data Recovery
- Capacity
- 8 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Buffer Size
- 256 MB
- Bytes per Sector
- 4096
- 101.85 mm
- 146.99 mm
- 26.11 mm
- 650 g
- Bundled with
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 214 MBps
- Average Latency
- 4.16 ms
- Spindle Speed
- 7200 rpm
Reliability
- MTBF
- 1,200,000 hours
- 24x7 Operation
- Non-Recoverable Errors
- 1 per 10^15
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 3.5"
- Power Consumption
- 2 Watt (start) , 4.4 Watt (idle) , 6.8 Watt (average) , 0.8 Watt (standby) , 0.8 Watt (sleep)
- NMB-3 Class B, CAN ICES-3 Class B
- Limited warranty - 5 years , Technical support - data recovery - 2 years
- 5 °C
- 60 °C
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Shock Tolerance (operating)
- 70 g @ 2 ms
- Shock Tolerance (non-operating)
- 250 g @ 2 ms
- Vibration Tolerance (non-operating)
- 2.27 g @ 10-500 Hz
