Seagate 8TB Innov8 3.5" USB3.1 Type External Hard Drive
Quicklinx: C3LHWS00 Mfr#: STFG8000400
Enter a era of personal desktop storage with the remarkable Seagate Innov8. With a staggering storage, it can be placed exactly where needed - right next to you. Back up and access your entire universe of favorite music and videos, along with all of your other important documents, projects and irreplaceable photos.
Innov8 is the first 8 TB USB-C powered external desktop storage solution on the market. A single, reversible USB-C cable powers the Innov8 and provides easy access to the massive 8 TB of storage. Just connect Innov8 to your computer and you are set.
  • Totally ambitious - inside and out
  • Desktop storage powered by USB-C
  • Ignition Boost Technology, by Seagate
    Ignition Boost technology is a true engineering milestone and breakthrough. Combined with USB 3.1 technology, Ignition Boost eliminates the need for a power adapter on an 8 TB desktop hard drive for the first time.
  • Art imitates engineering
    Innov8's premium all-aluminum enclosure is sturdy and well-balanced. The stacked, wraparound layers frame a confident design and a chiselled manufacturing finesse. They reinforce the durability and singular purpose of the drive's architecture.
Seagate Innov8 STFG8000400 - hard drive - 8 TB - USB 3.1 Gen 1
Hard drive - external (desktop)
8 TB
USB 3.1 Gen 1 - USB-C
Data Transfer Rate
10.0 Gbps (USB 3.1) / 5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0)
Seagate Ignition Boost
Power Source
USB bus
12.36 cm x 3.6 cm x 20.8 cm
1.5 kg
Worldwide
8 TB
USB 3.1 Gen 1
12.36 cm
3.6 cm
20.8 cm
1.5 kg
Performance
Interface Transfer Rate
Expansion & Connectivity
1 x USB 3.1 Gen 1 - 24 pin USB-C
Power Source
USB bus
Software Included
Driver, Seagate Backup Dashboard
Apple MacOS X 10.11 or later, Windows 8 or later
1 x USB-C cable - external
Enclosure Material
Aluminium
Worldwide
