Seagate 8TB BarraCuda Pro SATA 6GB/s 7200RPM Hard Drive
Quicklinx: D9X5WS00 Mfr#: ST8000DM0004
Select:
  • 8TB
BarraCuda leads the industry with the highest capacities for desktops and mobile computers. The BarraCuda portfolio is a great option for upgrades at any price point. The uncompromising BarraCuda Pro marries industry-leading storage capacity with 7,200 RPM spin speeds for snappy performance and load times when gaming or performing heavy workloads.
  • Robust durability
    Engineered to withstand the rigors of heavy use, the Seagate Barracuda Pro offers a high non-recoverable error rate of 1 per 10^15 and a substantial load/unload cycle of 300,000, ensuring reliability and data integrity over time.
  • Energy efficient
    With a power consumption profile that includes 6.8 W in active mode and as low as 0.8 W in standby and sleep modes, this hard drive is designed for energy efficiency, reducing operational costs.
  • High capacity storage
    Boasting an 8 TB capacity, this hard drive provides ample space for large-scale storage needs, making it an ideal choice for professionals and enthusiasts alike.
  • Fast data transfer
    Features like Native Command Queuing (NCQ) and a Serial ATA-600 interface facilitate a swift internal data rate of 220 MBps and a data transfer rate of 600 MBps, enhancing overall system performance.
  • Enhanced durability
    The Seagate Barracuda Pro is built to last, with a mean time between failures (MTBF) of 1,000,000 hours, ensuring peace of mind and reliability.
Seagate Barracuda Pro ST8000DM0004 - hard drive - 8 TB - SATA 6Gb/s
Hard drive - internal
8 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
256 MB
Spindle Speed
7200 rpm
Native Command Queuing (NCQ), Halogen Free, Perpendicular Magnetic Recording (PMR), PowerChoice, Hot-Plug Support, advanced format 512e, S.M.A.R.T.
101.85 mm x 146.99 mm x 26.11 mm
650 g
5-year warranty
Bundled with
Seagate Rescue Data Recovery
8 TB
3.5"
SATA 6Gb/s
Buffer Size
256 MB
Bytes per Sector
4096
101.85 mm
146.99 mm
26.11 mm
650 g
Bundled with
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
220 MBps
Average Latency
4.16 ms
Spindle Speed
7200 rpm
Reliability
MTBF
1,000,000 hours
Non-Recoverable Errors
1 per 10^15
Load / Unload Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
Power Consumption
6.8 Watt (active) , 4.5 Watt (idle) , 0.8 Watt (standby) , 0.8 Watt (sleep)
RoHS, NMB-3 Class B, CAN ICES-3 Class B
Limited warranty - 5 years , Technical support - data recovery - 2 years
60 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
5 - 95%
Shock Tolerance (operating)
70 g @ 2 ms
Shock Tolerance (non-operating)
250 g @ 2 ms
Vibration Tolerance (operating)
0.25 g @ 350-500 Hz
Vibration Tolerance (non-operating)
2.27 g @ 2-500 Hz
Sound Emission
34 dB
