BarraCuda leads the industry with the highest capacities for desktops and mobile computers. The BarraCuda portfolio is a great option for upgrades at any price point. The uncompromising BarraCuda Pro marries industry-leading storage capacity with 7,200 RPM spin speeds for snappy performance and load times when gaming or performing heavy workloads.
Robust durability
Engineered to withstand the rigors of heavy use, the Seagate Barracuda Pro offers a high non-recoverable error rate of 1 per 10^15 and a substantial load/unload cycle of 300,000, ensuring reliability and data integrity over time. -
Energy efficient
With a power consumption profile that includes 6.8 W in active mode and as low as 0.8 W in standby and sleep modes, this hard drive is designed for energy efficiency, reducing operational costs. -
High capacity storage
Boasting an 8 TB capacity, this hard drive provides ample space for large-scale storage needs, making it an ideal choice for professionals and enthusiasts alike. -
Fast data transfer
Features like Native Command Queuing (NCQ) and a Serial ATA-600 interface facilitate a swift internal data rate of 220 MBps and a data transfer rate of 600 MBps, enhancing overall system performance. -
Enhanced durability
The Seagate Barracuda Pro is built to last, with a mean time between failures (MTBF) of 1,000,000 hours, ensuring peace of mind and reliability.
- Seagate Barracuda Pro ST8000DM0004 - hard drive - 8 TB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 8 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 256 MB
- Spindle Speed
- 7200 rpm
- Native Command Queuing (NCQ), Halogen Free, Perpendicular Magnetic Recording (PMR), PowerChoice, Hot-Plug Support, advanced format 512e, S.M.A.R.T.
- 101.85 mm x 146.99 mm x 26.11 mm
- 650 g
- 5-year warranty
- Bundled with
- Seagate Rescue Data Recovery
- Capacity
- 8 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Buffer Size
- 256 MB
- Bytes per Sector
- 4096
- 101.85 mm
- 146.99 mm
- 26.11 mm
- 650 g
- Bundled with
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 220 MBps
- Average Latency
- 4.16 ms
- Spindle Speed
- 7200 rpm
Reliability
- MTBF
- 1,000,000 hours
- Non-Recoverable Errors
- 1 per 10^15
- Load / Unload Cycles
- 300,000
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 3.5"
- Power Consumption
- 6.8 Watt (active) , 4.5 Watt (idle) , 0.8 Watt (standby) , 0.8 Watt (sleep)
- RoHS, NMB-3 Class B, CAN ICES-3 Class B
- Limited warranty - 5 years , Technical support - data recovery - 2 years
- 0 °C
- 60 °C
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- 5 - 95%
- Shock Tolerance (operating)
- 70 g @ 2 ms
- Shock Tolerance (non-operating)
- 250 g @ 2 ms
- Vibration Tolerance (operating)
- 0.25 g @ 350-500 Hz
- Vibration Tolerance (non-operating)
- 2.27 g @ 2-500 Hz
- Sound Emission
- 34 dB
