Seagate 6TB SkyHawk 3.5" SATA 6Gb/s 256MB Surveillance Hard Drive
Quicklinx: DZ83WS00 Mfr#: ST6000VX001
SkyHawk leverages Seagate's extensive experience in designing drives purpose-built for surveillance applications.
Seagate SkyHawk Surveillance HDD ST6000VX001 - hard drive - 6 TB - SATA 6Gb/s
Hard drive - internal
6 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
256 MB
Surveillance system compatible, ImagePerfect firmware
101.85 mm x 146.99 mm x 26.11 mm
610 g
3-year warranty
6 TB
3.5"
SATA 6Gb/s
Buffer Size
256 MB
101.85 mm
146.99 mm
26.11 mm
610 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
180 MBps
Reliability
MTBF
1,000,000 hours
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
Power Consumption
5 watt (active) , 3.4 watt (idle) , 0.25 watt (sleep) , 0.25 watt (standby)
Limited warranty - 3 years
70 °C
