BarraCuda leads the industry with the highest capacities for desktops and mobile computers. The BarraCuda portfolio is a great option for upgrades at any price point. The uncompromising BarraCuda Pro marries industry-leading storage capacity with 7,200 RPM spin speeds for snappy performance and load times when gaming or performing heavy workloads.
Enhanced durability
With a robust load/unload cycle of 300,000 times, this hard drive is designed for longevity and reliability, ensuring your data remains safe over extensive use. -
Efficient power consumption
Optimized for energy efficiency, the Seagate Barracuda Pro consumes only 2 W in start mode and maintains low power usage across various operational modes, including a mere 0.6 W in standby and sleep modes, making it an eco-friendly choice for your computing needs. -
High-capacity storage
Boasting a generous 6 TB capacity, this hard drive offers ample space for all your storage needs, from high-resolution photos and videos to extensive game libraries and important documents, all in one place.
- Seagate Barracuda Pro ST6000DM004 - hard drive - 6 TB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 6 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 256 MB
- Spindle Speed
- 7200 rpm
- Native Command Queuing (NCQ), Halogen Free
- 101.6 mm x 146.99 mm x 26.11 mm
- 780 g
- 5-year warranty
- Capacity
- 6 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Buffer Size
- 256 MB
- Bytes per Sector
- 4096
- 101.6 mm
- 146.99 mm
- 26.11 mm
- 780 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 220 MBps
- Spindle Speed
- 7200 rpm
Reliability
- Non-Recoverable Errors
- 1 per 10^15
- Load / Unload Cycles
- 300,000
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 3.5"
- Power Consumption
- 2 Watt (start) , 9 Watt (active) , 7.2 Watt (idle) , 0.6 Watt (standby) , 0.6 Watt (sleep)
- RoHS
- Limited warranty - 5 years
- 0 °C
- 60 °C
