Seagate 6TB Barracuda Pro 3.5" SATA 6GB/s 7200RPM 256MB Hard Drive
Quicklinx: CNXGWS00 Mfr#: ST6000DM004
BarraCuda leads the industry with the highest capacities for desktops and mobile computers. The BarraCuda portfolio is a great option for upgrades at any price point. The uncompromising BarraCuda Pro marries industry-leading storage capacity with 7,200 RPM spin speeds for snappy performance and load times when gaming or performing heavy workloads.
  • Enhanced durability
    With a robust load/unload cycle of 300,000 times, this hard drive is designed for longevity and reliability, ensuring your data remains safe over extensive use.
  • Efficient power consumption
    Optimized for energy efficiency, the Seagate Barracuda Pro consumes only 2 W in start mode and maintains low power usage across various operational modes, including a mere 0.6 W in standby and sleep modes, making it an eco-friendly choice for your computing needs.
  • High-capacity storage
    Boasting a generous 6 TB capacity, this hard drive offers ample space for all your storage needs, from high-resolution photos and videos to extensive game libraries and important documents, all in one place.
Seagate Barracuda Pro ST6000DM004 - hard drive - 6 TB - SATA 6Gb/s
Hard drive - internal
6 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
256 MB
Spindle Speed
7200 rpm
Native Command Queuing (NCQ), Halogen Free
101.6 mm x 146.99 mm x 26.11 mm
780 g
5-year warranty
6 TB
3.5"
SATA 6Gb/s
Buffer Size
256 MB
Bytes per Sector
4096
101.6 mm
146.99 mm
26.11 mm
780 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
220 MBps
Spindle Speed
7200 rpm
Reliability
Non-Recoverable Errors
1 per 10^15
Load / Unload Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5"
Power Consumption
2 Watt (start) , 9 Watt (active) , 7.2 Watt (idle) , 0.6 Watt (standby) , 0.6 Watt (sleep)
RoHS
Limited warranty - 5 years
60 °C
