Easy backup with integrated USB 3.0 hub to manage and charge your devices
The Seagate® Backup Plus Hub drive optimises external storage with simple local or cloud file backup for your computers and mobile devices - and an intelligent USB hub to charge and manage your USB-connected devices.
High-speed USB 3.0 and 2.0 connectivity offers plug-and-play functionality on your PC. The drive is formatted for Windows computers - install the provided NTFS driver for Mac® on your Mac computer, and you can use the drive interchangeably between Windows and Mac computers without reformatting.
The two front-facing intelligent USB 3.0 ports amplify the functionality of your drive by allowing you to charge and connect two external devices, like your phone, tablet or camera - even if your computer is in off/standby mode.
Via the downloadable Seagate Dashboard software, you are provided with tools for local, mobile, cloud and social media backup. Run a oneclick backup or schedule an automatic backup plan to protect your files in your Backup Plus Hub drive at your convenience.
Install the free Seagate Mobile Backup app on an iOS or Android mobile device, and you’ll be able to back up all of the pictures and videos from your device to your Seagate drive or to the cloud.
Protect photos, videos, and more-on the go
Life is full of amazing moments you want to remember forever. The Backup Plus portable drive goes where you go, providing easy, Plug-and-Play backups. So you know that no matter where "life happens, " your memories are always protected. -
Save your social life with a click
Think of how many photos you've shared on Facebook or Flickr. With Backup Plus, you can easily download them right to your drive, so even more of your life is safe and sound. -
Share your favorite moments instantly
With Backup Plus, your memories aren't "trapped" in your drive. Just a click lets you share photos and videos to Facebook and Flickr or YouTube right from your Backup Plus drive. -
Upgrade your connectivity in a snap
Getting a new computer with Thunderbolt technology or USB 3.0? Not a problem. Changing your connectivity is as easy as plugging in a new adapter. So even when you upgrade, your Backup Plus drive can upgrade right along with you.
- Seagate Backup Plus STEL6000200 - hard drive - 6 TB - USB 3.0
- Hard drive - external (desktop)
- Capacity
- 6 TB
- Interface
- USB 3.0
- Data Transfer Rate
- 5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0)
- Built-in USB hub, NTFS formatted
- Power Source
- Included AC adapter
- 41 mm x 198.1 mm x 118 mm
- 1.06 kg
- Localisation
- EMEA
- 2-year warranty
- Capacity
- 6 TB
- Interface
- USB 3.0
- 41 mm
- 198.1 mm
- 118 mm
- 1.06 kg
Performance
- Interface Transfer Rate
Expansion & Connectivity
- 2 x USB 3.0 (output) , 1 x USB 3.0 (input)
- Power Source
- Software Included
- Seagate Dashboard, NTFS driver for Mac
- OS Required
- Microsoft Windows 7 or later, Apple MacOS X 10.9 or later
- Cables Included
- 1 x USB 3.0 cable - 1.2 m
- Localisation
- EMEA
- Limited warranty - 2 years
