The Seagate Enterprise Capacity 3.5 HDD delivers high capacity without sacrificing performance for reliable access to bulk storage of unstructured data.
Enhanced reliability
Equipped with Enhanced Error Correction Code and a dual processor, the Seagate Enterprise Capacity 3.5 HDD V.4 ensures data integrity and efficient processing for demanding enterprise environments. -
Energy efficient
Featuring PowerChoice technology, this hard drive optimizes power consumption during idle periods, reducing operational costs and extending the lifespan of the drive. -
Durable design
With its Ramp Load technology, the drive offers increased shock resistance, ensuring data protection and drive longevity in various operational conditions.
- Seagate Enterprise Capacity 3.5 HDD V.4 ST5000NM0084 - hard drive - 5 TB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 5 TB
- Form Factor
- 3.5" x 1/3H
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 128 MB
- Spindle Speed
- 7200 rpm
- Enhanced Error Correction Code, Ramp Load, dual processor, PowerChoice, Humidity Sensor, Low Halogen, Super Parity, Hot-Plug Support
- 101.85 mm x 147 mm x 26.1 mm
- 780 g
- Microsoft Certification
- Compatible with Windows 7
- 5-year warranty
- Capacity
- 5 TB
- Form Factor
- 3.5" x 1/3H
- Interface
- SATA 6Gb/s
- Buffer Size
- 128 MB
- Bytes per Sector
- 512
- 101.85 mm
- 147 mm
- 26.1 mm
- 780 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 216 MBps
- Average Latency
- 4.16 ms
- Spindle Speed
- 7200 rpm
Reliability
- MTBF
- 1,400,000 hours
- Non-Recoverable Errors
- 1 per 10^15
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 3.5" x 1/3H
- Power Consumption
- 6.9 Watt (idle) , 11.27 Watt (read)
- Limited warranty - 5 years
- 5 °C
- 60 °C
- Vibration Tolerance
- 5 g @ 10-500 Hz (non-operating)
