Seagate 2.5-inch SATA Hard Drive
Feature-rich, slim, lightweight style at price and capacity points that enable no-compromise designs for thin computing.
• Compatible with SATA 6Gb/s and 3Gb/s designs
• Backed by a 2-year limited warranty
Please note, this hard drive does not have the Secure Laptop Encryption (SED) feature
Enhanced durability
Designed to withstand the rigors of daily use, the Seagate Momentus Thin features a shock tolerance storage of 1000 g @ 1 ms, ensuring your data remains safe even in the event of accidental drops or bumps. -
Optimized for quiet operation
The QuietStep technology incorporated into the Seagate Momentus Thin ensures a silent operation, making it an ideal choice for environments where noise levels are a concern. -
High compatibility
With its Serial ATA-300 interface and compatibility with Windows 7, the Seagate Momentus Thin offers seamless integration into most PC setups, ensuring a hassle-free upgrade or installation.
- Seagate Momentus Thin ST500LT012 - hard drive - 500 GB - SATA 3Gb/s
- Hard drive - internal
- Capacity
- 500 GB
- Form Factor
- 2.5"
- Interface
- SATA 3Gb/s
- Data Transfer Rate
- 300 MBps
- Buffer Size
- 16 MB
- Spindle Speed
- 5400 rpm
- QuietStep, Native Command Queuing (NCQ), Ramp Load, Advanced Format technology
- 70.1 mm x 100.55 mm x 7 mm
- 95 g
- Microsoft Certification
- Compatible with Windows 7
- Capacity
- 500 GB
- Form Factor
- 2.5"
- Interface
- SATA 3Gb/s
- Buffer Size
- 16 MB
- Bytes per Sector
- 4096
- 70.1 mm
- 100.55 mm
- 7 mm
- 95 g
Performance
- Drive Transfer Rate
- 300 MBps (external)
- Spindle Speed
- 5400 rpm
Reliability
- Non-Recoverable Errors
- 1 per 10^14
- Start / Stop Cycles
- 600,000
Expansion & Connectivity
- 1 x SATA 3 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 2.5"
- 0 °C
- 60 °C
- Shock Tolerance
- 400 g @ 2ms (operating) / 1000 g @ 1ms (non-operating)
