Seagate 500GB Laptop Thin SSHD SATA 6GB/s 64MB 7mm Hard Drive
Quicklinx: 8KRTWS00 Mfr#: ST500LM000
Seagate® Laptop and Laptop Thin SSHDs fuse the lightning speed of SSD with the high capacity of a hard drive. Powered by Seagate Adaptive Memory™ technology, SSHD improves boot times and application speed dramatically, unleashing your system's performance.
  • 500GB, 7mm design for the latest, thinnest laptops
  • Boots up and performs like an SSD
  • Up to 5 times faster than a traditional 5400-RPM HDD
  • Easy laptop upgrade to boost performance and capacity.
SSHDs use Seagate flash management technology to deliver SSD-like performance. Testing consistently shows that Seagate Laptop SSHDs compare favourably to SSDs--without sacrificing capacity.
SSD + HDD - The best of both worlds.
Seagate Laptop SSHDs integrate NAND flash solid-state storage with traditional hard drive storage, creating a laptop drive with the speed of solid state and the capacity of a hard drive.
  • No need to compromise performance over capacity
  • Installs and works like a typical hard drive
  • Unmatched data integrity and reliability by maximising the strengths of both flash and hard drive storage
  • Performance optimised by Seagate Adaptive Memory™ technology
SSHD is affordable.
SSHDs fuse the strength of SSD and HDD into one affordable and powerful device. You do not have to compromise capacity over performance anymore. With an SSHD, you can have it all. It is the latest and most affordable way to maximise every penny you invest in your PC.
Easy, low-cost HDD laptop upgrade: SSHD provides a great way to breath new life into an older laptop computer.
  • Get performance you never thought possible from your old system
  • One of the most cost-effective ways to increase performance in your PC or MAC system.
  • Easy DIY laptop upgrade solutions available
Seagate Adaptive Memory™ technology effectively identifies the most frequently-used data in your computer. This data is stored in the ultra-fast NAND flash memory, which results in blazing fast boot times and a super-responsive experience where you wait less and do more. This technology is constantly working and adapting to the way you work and access information.
PC & Mac Compatible.
Your Seagate® Laptop SSHD or Laptop Thin SSHD is designed to work in any standard laptop system. Unlike other "hyrbrid" solutions, there are no special drivers or software to install and configure. It installs and works just like a hard drive - only faster!
Affordable and reliable SSHD for your laptop.
SSHDs fuse the strength of SSD and HDD into one affordable and powerful device. You'll be surprised at how little you have to pay to get SSD-like performance in your laptop.
And since SSD fuses the strengths of both HDD and SSD technologies, you get the combined reliability of both in a solid state hybrid drive product.
  • Enhanced durability
    With a robust design that includes Ramp Load technology, the Seagate Laptop Thin SSHD is engineered to withstand up to 600,000 Start / Stop cycles, ensuring reliability and performance for your computing needs.
  • Efficient operation
    The hybrid hard drive's power consumption is optimized at just 2.5 W, making it an efficient choice for laptop users who demand performance without compromising on battery life.
  • Optimized speed
    Featuring a hybrid drive cache of 8 GB, this SSHD combines the speed of SSD with the capacity of traditional hard drives, offering a data transfer rate of 600 MBps for quicker boot times and faster file access.
Seagate Laptop Thin SSHD - hybrid hard drive - 500 GB - SATA 6Gb/s
Hybrid hard drive - internal
500 GB
Flash Memory Capacity
8 GB
NAND Flash Memory Type
Multi-level cell (MLC)
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
Spindle Speed
5400 rpm
QuietStep, Native Command Queuing (NCQ), Ramp Load
69.85 mm x 100.35 mm x 7 mm
95 g
3-year warranty
500 GB
8 GB
2.5"
SATA 6Gb/s
Buffer Size
64 MB
Bytes per Sector
4096
69.85 mm
100.35 mm
7 mm
95 g
Performance
Drive Transfer Rate
600 MBps (external)
Seek Time
12 ms (average) / 14 ms (max)
Spindle Speed
5400 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Start / Stop Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5"
Power Consumption
2.5 watt (active) , 0.9 watt (idle)
Limited warranty - 3 years
60 °C
Shock Tolerance
350 g @ 2ms
