Seagate 500GB FreeAgent GoFlex USB 2.0 2.5" Black
PRICED TO CLEAR - WHILST STOCKS LAST
Quicklinx: 72YJWS00 Mfr#: STAA500200
As the world's most upgradable portable hard drive - and the core of the GoFlex Storage System - the GoFlex ultra-portable drive gives you high transfer speeds and the flexibility you need to extend your digital life wherever you go. With the GoFlex ultra-portable hard drive it's easy to manage your backup schedules, encrypt your files, and view your drive's statistics.
  • Automatic backups that are always secure
  • Flexibility is built in
    Seagate has created the GoFlex Storage System - which includes the GoFlex ultra-portable drive - to make it easy for you to upgrade your interface for faster transfer speeds, and access your content on your network, your TV, and everywhere you go.
Seagate FreeAgent GoFlex - hard drive - 500 GB - USB 2.0
Hard drive - external (portable)
500 GB
USB 2.0
Data Transfer Rate
480 Mbps
Power Source
USB bus
Enclosure Colour
8.3 cm x 11.1 cm x 1.5 cm
150 g
Middle East, Africa, Europe
Microsoft Certification
Compatible with Windows 7
3-year warranty
500 GB
USB 2.0
8.3 cm
11.1 cm
1.5 cm
150 g
Performance
Interface Transfer Rate
480 Mbps
Expansion & Connectivity
1 x USB 2.0
Power Source
USB bus
Software Included
Drivers & Utilities
Microsoft Windows Vista / XP / 7, Apple MacOS X 10.4.6 or later
USB 2.0 controller
1 x USB cable - 46 cm
Enclosure Colour
Limited warranty - 3 years
