- Seagate Barracuda ST500DM009 - hard drive - 500 GB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 500 GB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 32 MB
- Spindle Speed
- 7200 rpm
- Native Command Queuing (NCQ), Halogen Free, Seagate OptiCache technology, Seagate SmartAlign technology, Hot-Plug Support, TGMR recording technology, advanced format 512e, S.M.A.R.T.
- 101.6 mm x 146.99 mm x 20.17 mm
- 400 g
- 2-year warranty
- Capacity
- 500 GB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Buffer Size
- 32 MB
- Bytes per Sector
- 4096
- 101.6 mm
- 146.99 mm
- 20.17 mm
- 400 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 210 MBps
- Seek Time
- 8.5 ms (average)
- Track-to-Track Seek Time
- 1 ms
- Average Latency
- 4.16 ms
- Spindle Speed
- 7200 rpm
Reliability
- Non-Recoverable Errors
- 1 per 10^14
- Load / Unload Cycles
- 300,000
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 3.5"
- Power Consumption
- 5.3 watt (active) , 4.6 watt (idle) , 0.94 watt (standby) , 0.94 watt (sleep)
- RoHS
- Limited warranty - 2 years
- 0 °C
- 60 °C
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- 5 - 95% (non-condensing)
- Shock Tolerance (operating)
- 80 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 350 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.5 g @ 22-350 Hz
- Vibration Tolerance (non-operating)
- 3 g @ 22-350 Hz
