Brand
Seagate 500GB BarraCuda SATA 6Gb/s 32MB 3.5" Internal Drive
Quicklinx: CBLHWS00 Mfr#: ST500DM009
Form Factor: 3.5"
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 500GB, 500GB
Spin Speed (rpm): 7200rpm
£33.61 ex VAT
£40.33 inc VAT
Versatile. Fast. Dependable. The fiercest hard drive you've ever met.
Seagate Barracuda ST500DM009 - hard drive - 500 GB - SATA 6Gb/s
Hard drive - internal
500 GB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
32 MB
Spindle Speed
7200 rpm
Native Command Queuing (NCQ), Halogen Free, Seagate OptiCache technology, Seagate SmartAlign technology, Hot-Plug Support, TGMR recording technology, advanced format 512e, S.M.A.R.T.
101.6 mm x 146.99 mm x 20.17 mm
400 g
500 GB
3.5"
SATA 6Gb/s
Buffer Size
32 MB
Bytes per Sector
4096
101.6 mm
146.99 mm
20.17 mm
400 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
210 MBps
Seek Time
8.5 ms (average)
Track-to-Track Seek Time
1 ms
Average Latency
4.16 ms
Spindle Speed
7200 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
Power Consumption
5.3 Watt (active) , 4.6 Watt (idle) , 0.94 Watt (standby) , 0.94 Watt (sleep)
RoHS
60 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
5 - 95% (non-condensing)
Shock Tolerance (operating)
80 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
350 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.5 g @ 22-350 Hz
Vibration Tolerance (non-operating)
3 g @ 22-350 Hz
Form Factor: 3.5"
Type: Hard drive
Capacity: 500GB
Capacity: 500GB
Brand: Seagate
