Seagate 500GB BarraCuda 2.5" SATA 6Gb/s 128MB 5400RPM Hard Drive
Quicklinx: CGZHWS00 Mfr#: ST500LM030
Form Factor: 2.5
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 500GB, 500GB
Spin Speed (rpm): 5400rpm
More than 50 In Stock
£35.95 ex VAT
£43.14 inc VAT
BarraCuda leads the industry with the highest capacities for desktops and mobile computers. The uncompromising BarraCuda Pro marries industry-leading storage capacity with 7,200-RPM spin speeds for snappy performance and load times when gaming or performing heavy workloads.
Get the most out of your storage with BarraCuda hard drives. From computers full of photos and memories to gaming PCs that need more room to play, BarraCuda grows with you.
  • Enhanced durability
    With a robust design that includes Ramp Load technology, the Seagate Guardian BarraCuda ensures reliability by minimizing wear and tear. Its ability to withstand up to 600,000 load/unload cycles makes it a durable choice for demanding environments.
  • Energy efficient
    Optimized for efficiency, this hard drive consumes only 1.6 W during read operations and 1.7 W during write operations, with an idle power consumption of just 0.45 W. This low power usage translates into reduced energy costs and a smaller carbon footprint.
  • High compatibility
    Designed to seamlessly integrate into any PC setup, this internal hard drive features a Serial ATA-600 interface, ensuring high-speed data transfers and compatibility with a wide range of systems.
  • Quiet operation
    Featuring QuietStep technology, the Seagate Guardian BarraCuda operates with minimal noise, making it an ideal choice for use in quiet environments where maintaining a low noise level is essential.
Seagate Guardian BarraCuda ST500LM030 - hard drive - 500 GB - SATA 6Gb/s
Hard drive - internal
500 GB
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
128 MB
Spindle Speed
5400 rpm
QuietStep, Halogen Free, Ramp Load
69.85 mm x 100.35 mm x 7 mm
90 g
500 GB
2.5"
SATA 6Gb/s
Buffer Size
128 MB
Bytes per Sector
4096
69.85 mm
100.35 mm
7 mm
90 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
140 MBps
Spindle Speed
5400 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
600,000
Expansion & Connectivity
SATA 6 Gb/s
Compatible Bay
2.5"
Power Consumption
1.6 Watt (read) , 1.7 Watt (write) , 0.45 Watt (idle)
RoHS
60 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Shock Tolerance (operating)
400 g @ 2 ms
Shock Tolerance (non-operating)
1000 g @ 1 ms
Form Factor: 2.5
Type: Hard drive
Capacity: 500GB
Capacity: 500GB
Brand: Seagate
