Seagate 500GB BarraCuda 2.5" SATA 6Gb/s 128MB 5400RPM Hard Drive
Quicklinx: CGZHWS00 Mfr#: ST500LM030
Form Factor: 2.5
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 500GB, 500GB
Spin Speed (rpm): 5400rpm
More than 50 In Stock
£39.73 ex VAT
£47.67 inc VAT
BarraCuda leads the industry with the highest capacities for desktops and mobile computers. The uncompromising BarraCuda Pro marries industry-leading storage capacity with 7,200-RPM spin speeds for snappy performance and load times when gaming or performing heavy workloads.
Get the most out of your storage with BarraCuda hard drives. From computers full of photos and memories to gaming PCs that need more room to play, BarraCuda grows with you.
  • Versatile, fast and dependable
  • Amazing versatility
  • 3.5-inch Barracuda hard drives deliver
    Rock-solid reliability built on over 20 years of BarraCuda innovation. Versatile mix of capacity and price point options to fit any budget. Multi-Tier Caching Technology for excellent hard drive performance.
  • Multi-Tier Caching Technology
    All hard drives in the BarraCuda family come equipped with Multi-Tier Caching Technology (MTC). MTC takes your PC to the performance levels, so you can load applications and files faster than ever before. By applying intelligent layers of NAND Flash, DRAM and media cache technologies, BarraCuda delivers improved read and write performance by optimizing data flow.
Seagate Guardian BarraCuda ST500LM030 - hard drive - 500 GB - SATA 6Gb/s
Hard drive - internal
500 GB
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
128 MB
Spindle Speed
5400 rpm
QuietStep, Halogen Free, Ramp Load
69.85 mm x 100.35 mm x 7 mm
90 g
500 GB
2.5"
SATA 6Gb/s
Buffer Size
128 MB
Bytes per Sector
4096
69.85 mm
100.35 mm
7 mm
90 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
140 MBps
Spindle Speed
5400 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
600,000
Expansion & Connectivity
SATA 6 Gb/s
Compatible Bay
2.5"
Power Consumption
1.6 Watt (read) , 1.7 Watt (write) , 0.45 Watt (idle)
RoHS
60 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Shock Tolerance (operating)
400 g @ 2 ms
Shock Tolerance (non-operating)
1000 g @ 1 ms
Form Factor: 2.5
Type: Hard drive
Capacity: 500GB
Capacity: 500GB
Brand: Seagate
