Seagate 4TB Surveillance HDD SATA 6Gb/s 5900RPM 64MB 3.5" Hard Drive
Quicklinx: 9KJ3WS00 Mfr#: ST4000VX000
The Seagate Surveillance HDD addresses the need for high-resolution cameras and camera counts, and ensures cost-effective performance and durability in always-on surveillance systems.
  • Build better video surveillance systems
    The Surveillance HDD features storage power for the video surveillance systems.
  • Consistent performance in multi-drive surveillance systems
    Improve your drive reliability with drives built for surveillance applications that include the flexibility to scale as your data grows.
  • Improved time-to-ready for motion sensing cameras
    As drive technology evolves, so do the applications that leverage them. With improvements in motion sensing cameras, the Surveillance HDD now includes settings that can ensure your drive is ready when your system needs to record.
  • Surveillance hard drives with enterprise-class reliability
    Surveillance HDD is engineered for high write workloads and multiple video stream recording.
Seagate Surveillance HDD ST4000VX000 - hard drive - 4 TB - SATA 6Gb/s
Hard drive - internal
4 TB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
Spindle Speed
5900 rpm
RV Sensor, Native Command Queuing (NCQ), Seagate Think Green, Advanced Format technology
101.6 mm x 146.99 mm x 26.11 mm
610 g
3-year warranty
4 TB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
64 MB
101.6 mm
146.99 mm
26.11 mm
610 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
146 MBps
Seek Time
8.5 ms (average)
Spindle Speed
5900 rpm
Reliability
MTBF
1,000,000 hours
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5" x 1/3H
Power Consumption
8 Watt (active) , 0.75 Watt (standby) , 0.75 Watt (sleep)
Limited warranty - 3 years
70 °C
5 - 90% (non-condensing)
Shock Tolerance
80 g @ 2ms (operating) / 300 g @ 2ms (non-operating)
