Brand
Seagate 4TB SkyHawk 3.5" SATA 6Gb/s 64MB Surveillance Hard Drive
Quicklinx: CH03WS00 Mfr#: ST4000VX007
Form Factor: 3.5"
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 4TB
20 in stock
£82.70 ex VAT
£99.24 inc VAT
Smart. Safe. Secure. Seagate provides drives specifically for surveillance storage for years. SkyHawk is built to keep systems in the field longer and reduce the need for post-deployment support.
Seagate SkyHawk Surveillance HDD ST4000VX007 - hard drive - 4 TB - SATA 6Gb/s
Hard drive - internal
4 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
Surveillance system compatible, 24x7 continuous operation, rotation vibration sensor, ImagePerfect firmware
101.85 mm x 146.99 mm x 26.11 mm
635 g
3-year warranty
4 TB
3.5"
SATA 6Gb/s
Buffer Size
64 MB
101.85 mm
146.99 mm
26.11 mm
635 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
190 MBps
Reliability
MTBF
1,000,000 hours
24x7 Operation
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
Power Consumption
5.5 Watt (active) , 3.2 Watt (idle) , 0.25 Watt (standby) , 0.25 Watt (sleep)
Limited warranty - 3 years
70 °C
Min Storage Temperature
-40 °C
Form Factor: 3.5"
Type: Hard drive
Capacity: 4TB
Brand: Seagate
Stock Status: In stock
