Seagate 4TB Pipeline SATA 6Gb/s 5900RPM 64MB 3.5" Hard Drive
Quicklinx: 9GKFWS00 Mfr#: ST4000VM000
Seagate Video 3.5 HDD is designed to deliver reliable 24 x 7 operation - optimized for low-power consumption, quiet operation, smooth video streaming, high reliability and high capacity.
  • Always on, always reliable DVR storage
    Media technology demands both reliability and energy efficiency. Seagate Video 3.5 HDD delivers low overall power consumption profiles, cool operating temperatures and good AFRs. Low-power profiles help DVR manufacturers achieve reduced overall power requirements and support ENERGY STAR compliance.
  • Performance and low-power consumption
    Video 3.5 HDD meets the rising demand for energy-conserving consumer electronics without compromising performance. Seagate is committed to environmental stewardship that goes well beyond reduced power consumption. In fact, the Video 3.5 HDD is a value proposition for sustainability by design.
Seagate Video 3.5 HDD ST4000VM000 - hard drive - 4 TB - SATA 6Gb/s
Hard drive - internal
4 TB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
Native Command Queuing (NCQ), Halogen Free
101.6 mm x 146.99 mm x 26.11 mm
610 g
4 TB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
64 MB
101.6 mm
146.99 mm
26.11 mm
610 g
Performance
Drive Transfer Rate
600 MBps (external)
Reliability
Non-Recoverable Errors
1 per 10^14
Start / Stop Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5" x 1/3H
70 °C
5 - 90% (non-condensing)
Shock Tolerance
80 g @ 10ms duration (operating) / 300 g @ 2ms (non-operating)
