Seagate 4TB IronWolf 3.5" SATA 6Gb/s 5900RPM 64MB Hard Drive
Quicklinx: CGZVWS00 Mfr#: ST4000VN008
Form Factor: 3.5
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 4TB
Spin Speed (rpm): 5900rpm
Hurry, only 2 left in stock!
£84.92 ex VAT
£101.90 inc VAT
The Power of Agility for home, SOHO and SMB NAS enclosures. IronWolf is designed for everything NAS. Get used to tough, ready and scalable 24/7 performance that can handle multi-drive environments with a wide range of capacities.
Seagate IronWolf ST4000VN008 - hard drive - 4 TB - SATA 6Gb/s
Hard drive - internal
4 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
Spindle Speed
5900 rpm
Halogen Free, NAS compatible, 24x7 availability, Dual-Plane Balance, Error Recovery Control
101.6 mm x 146.99 mm x 26.11 mm
610 g
3-year warranty
4 TB
3.5"
SATA 6Gb/s
Buffer Size
64 MB
101.6 mm
146.99 mm
26.11 mm
610 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
180 MBps
Spindle Speed
5900 rpm
Reliability
MTBF
1,000,000 hours
24x7 Operation
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
Power Consumption
2 Watt (start) , 4.8 Watt (active) , 3.95 Watt (idle) , 0.5 Watt (standby) , 0.5 Watt (sleep)
Limited warranty - 3 years
5 °C
70 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Shock Tolerance (operating)
80 g @ 2 ms
Shock Tolerance (non-operating)
300 g @ 2 ms
Form Factor: 3.5
Type: Hard drive
Capacity: 4TB
Brand: Seagate
Stock Status: While stocks last
Stock Status: Clearance
