Seagate 4TB BarraCuda 3.5" SATA 6Gb/s 256MB Cache Hard Drive
Quicklinx: D336WS00 Mfr#: ST4000DM004
Form Factor: 3.5
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 4TB
Spin Speed (rpm): 5400rpm
19 In Stock
£157.55 ex VAT
£189.06 inc VAT
Get the most out of your storage with BarraCuda hard drives. From computers full of photos and memories to gaming PCs that need more room to play, BarraCuda grows with you.
  • Amazing versatility
  • External and all-in-one PC storage
    BarraCuda hard drives provide amazing storage for your important and critical work files, as well as those you personally treasure the most. This drive is an excellent solution for taking your external hard drive to the next level or bumping up the storage on your all-in-one or slim PC.
  • Multi-Tier Caching technology
    All hard drives in the BarraCuda family come equipped with Multi-Tier Caching technology (MTC). MTC takes your PC to high performance levels, so you can load applications and files faster. By applying intelligent layers of NAND Flash, DRAM and media cache technologies, BarraCuda delivers improved read and write performance by optimizing data flow.
Seagate Barracuda ST4000DM004 - hard drive - 4 TB - SATA 6Gb/s
Hard drive - internal
4 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
256 MB
Spindle Speed
5400 rpm
Halogen Free, Seagate Multi-Tier Caching Technology (MTC)
101.6 mm x 146.99 mm x 20.17 mm
490 g
4 TB
3.5"
SATA 6Gb/s
Buffer Size
256 MB
Bytes per Sector
4096
101.6 mm
146.99 mm
20.17 mm
490 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
190 MBps
Spindle Speed
5400 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
Power Consumption
5 Watt (active) , 2.5 Watt (idle) , 0.25 Watt (standby) , 0.25 Watt (sleep)
RoHS
60 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Form Factor: 3.5
Type: Hard drive
Capacity: 4TB
Brand: Seagate
