Seagate 3TB SkyHawk 3.5" SATA 6Gb/s 256MB Surveillance Hard Drive
Quicklinx: DZ82WS00 Mfr#: ST3000VX009
SkyHawk leverages Seagate's extensive experience in designing drives purpose-built for surveillance applications.
  • Robust storage capacity
    With a generous 3 TB capacity, this Seagate SkyHawk Surveillance HDD offers ample space for storing large volumes of data, making it ideal for surveillance systems that require extensive video storage capabilities.
  • Durable design
    Engineered for high-load cycles, the hard drive boasts 300,000 load/unload cycles, ensuring reliability and durability for continuous operation in demanding environments.
  • Efficient performance
    Featuring a fast data transfer rate of 600 MB/s and an internal data rate of 180 MB/s, this HDD ensures swift read/write speeds, enhancing the efficiency of surveillance operations.
  • Optimized for surveillance
    Equipped with ImagePerfect firmware, the Seagate SkyHawk is specifically designed to minimize frame loss and ensure smooth video streaming, making it compatible with a wide range of surveillance systems.
  • Energy-conscious operation
    With power consumption modes optimized for surveillance applications, including active, idle, sleep, and standby modes, this HDD balances performance with energy efficiency, reducing operational costs.
Seagate SkyHawk Surveillance HDD ST3000VX009 - hard drive - 3 TB - SATA 6Gb/s
Hard drive - internal
3 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
256 MB
Surveillance system compatible, ImagePerfect firmware
101.85 mm x 146.99 mm x 20.2 mm
490 g
3-year warranty
3 TB
3.5"
SATA 6Gb/s
Buffer Size
256 MB
101.85 mm
146.99 mm
20.2 mm
490 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
180 MBps
Reliability
MTBF
1,000,000 hours
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
Power Consumption
3.5 watt (active) , 2.5 watt (idle) , 0.25 watt (sleep) , 0.25 watt (standby)
Limited warranty - 3 years
70 °C
