SkyHawk leverages Seagate's extensive experience in designing drives purpose-built for surveillance applications.
Robust storage capacity
With a generous 3 TB capacity, this Seagate SkyHawk Surveillance HDD offers ample space for storing large volumes of data, making it ideal for surveillance systems that require extensive video storage capabilities. -
Durable design
Engineered for high-load cycles, the hard drive boasts 300,000 load/unload cycles, ensuring reliability and durability for continuous operation in demanding environments. -
Efficient performance
Featuring a fast data transfer rate of 600 MB/s and an internal data rate of 180 MB/s, this HDD ensures swift read/write speeds, enhancing the efficiency of surveillance operations. -
Optimized for surveillance
Equipped with ImagePerfect firmware, the Seagate SkyHawk is specifically designed to minimize frame loss and ensure smooth video streaming, making it compatible with a wide range of surveillance systems. -
Energy-conscious operation
With power consumption modes optimized for surveillance applications, including active, idle, sleep, and standby modes, this HDD balances performance with energy efficiency, reducing operational costs.
- Seagate SkyHawk Surveillance HDD ST3000VX009 - hard drive - 3 TB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 3 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 256 MB
- Surveillance system compatible, ImagePerfect firmware
- 101.85 mm x 146.99 mm x 20.2 mm
- 490 g
- 3-year warranty
- Capacity
- 3 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Buffer Size
- 256 MB
- 101.85 mm
- 146.99 mm
- 20.2 mm
- 490 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 180 MBps
Reliability
- MTBF
- 1,000,000 hours
- Non-Recoverable Errors
- 1 per 10^14
- Load / Unload Cycles
- 300,000
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 3.5"
- Power Consumption
- 3.5 Watt (active) , 2.5 Watt (idle) , 0.25 Watt (sleep) , 0.25 Watt (standby)
- Limited warranty - 3 years
- 0 °C
- 70 °C
