This Seagate laptop HDD is a high-capacity, high-performance random access storage device, which uses non-removable disks as storage media. Each disk incorporates thin film metallic media technology for enhanced performance and reliability. And for each disk surface there is a corresponding movable head actuator assembly to randomly access the data tracks and write or read the user data. The laptop HDD includes the AT controller embedded in the disk drive PCB electronics. The drive's electrical interface is compatible with all mandatory, optional and vendor-specific commands within the ATA specification. The laptop HDD incorporates TuMR head and Noise Predictive PRML (Partial Response Maximum Likelihood) signal processing technologies. These advanced technologies allow ample storage capacity. The heads, disk(s), and actuator housing are environmentally sealed within an aluminum-alloy base and cover. As the disks spin, air circulates within this base and cover, commonly referred to as the head and disk assembly (HDA), through a non-replaceable absolute filter ensuring a contamination-free environment for the heads and disks throughout the life of the drive.
2.5-inch laptop drives
Seagate's purpose-built the 2.5-inch laptop HDDs help meet customers' demand for affordable, flexible computing solutions. -
Smooth migration to Advanced Format 4K
Laptop thin HDDs include Seagate SmartAlign technology. This solution helps you easily get all the benefits of the Advanced Format (AF) 4K sector standard - no utilities, no extra steps - automatically in the background. Performance is not affected, and there is no need for time-consuming utilities required by other AF-enabled drives. -
Secure SED
Laptop thin SEDs deliver excellent encryption without performance degradation - protecting your data where it lives. You get all the benefits of secure data encryption without the headaches.
- Seagate Laptop HDD ST3000LM016 - hard drive - 3 TB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 3 TB
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 128 MB
- Spindle Speed
- 5400 rpm
- QuietStep, Ramp Load, advanced format 512e
- 69.85 mm x 100.35 mm x 15 mm
- 200 g
- 3-year warranty
- Capacity
- 3 TB
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Buffer Size
- 128 MB
- Bytes per Sector
- 4096
- 69.85 mm
- 100.35 mm
- 15 mm
- 200 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 130 MBps
- Seek Time
- 12 ms (average)
- Spindle Speed
- 5400 rpm
Reliability
- Non-Recoverable Errors
- 1 per 10^14
- Load / Unload Cycles
- 600,000
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 2.5"
- Power Consumption
- 1.9 Watt (read) , 2.1 Watt (write) , 0.85 Watt (idle)
- Limited warranty - 3 years
- 0 °C
- 60 °C
- Shock Tolerance (operating)
- 300 g @ 2 ms
- Shock Tolerance (non-operating)
- 650 g @ 1 ms
