Seagate 3TB Barracuda SATA 6Gb/s 256MB 3.5" HDD
Quicklinx: DS4WWS00 Mfr#: ST3000DM007
Form Factor: 3.5
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 3TB
Spin Speed (rpm): [N/A]
Hurry, only 1 left in stock!
£64.85 ex VAT
£77.82 inc VAT
The Barracuda family has earned awards and accolades around the globe. This is because Seagate has demonstrated a commitment to introduce technologies that allow people to work faster, do more, and feel great about making an investment in proven technology. And, for those who want the biggest, high performance drive available, the Barracuda choice is without peer.
  • Enhanced durability
    Designed to withstand the rigors of daily use, this hard drive features a robust load/unload cycle of 600,000, ensuring reliability and longevity. With shock acceleration tolerances of 80 g operating and 300 g non-operating, it's built to resist physical impacts and provide stable performance.
  • Efficient power consumption
    Optimized for energy efficiency, the Seagate Barracuda operates with a power consumption of just 3.7 W during read and write modes, and drops to a mere 0.25 W in standby and sleep modes, reducing overall energy costs and benefiting the environment.
  • High-capacity storage
    With a generous 3 TB capacity, this internal hard drive offers ample space for all your storage needs, from high-resolution photos and videos to large databases and application files, ensuring you have the room you need to store your valuable data.
  • Advanced technology for superior performance
    Incorporating TGMR recording technology along with support for Native Command Queuing (NCQ), Ultra DMA Mode 0-6, and Multi-Word DMA mode 0-2, this hard drive delivers high-speed data transfer rates up to 600 MBps, enhancing system efficiency and productivity.
Seagate Barracuda ST3000DM007 - hard drive - 3 TB - SATA 6Gb/s
Hard drive - internal
3 TB
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
256 MB
Native Command Queuing (NCQ), PIO mode 0-4 support, Multi-Word DMA mode 0-2 support, Ultra DMA Mode 0-6 support, Hot-Plug Support, Worldwide Name (WWN), TGMR recording technology, S.M.A.R.T.
101.6 mm x 146.99 mm x 20.17 mm
490 g
3 TB
SATA 6Gb/s
Buffer Size
256 MB
Bytes per Sector
4096
101.6 mm
146.99 mm
20.17 mm
490 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
190 MBps
Average Latency
6 ms
Reliability
Non-Recoverable Errors
1 per 10^15
Load / Unload Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Power Consumption
3.7 Watt (read) , 2.5 Watt (idle) , 3.7 Watt (write) , 0.25 Watt (standby) , 0.25 Watt (sleep)
Software Included
Seagate SeaTools
RoHS, China RoHS
60 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
5 - 90%
Shock Tolerance (operating)
80 g @ 2 ms
Shock Tolerance (non-operating)
300 g @ 2 ms
Vibration Tolerance (operating)
0.5 g @ 22-350 Hz
Vibration Tolerance (non-operating)
3 g @ 22-350 Hz
Form Factor: 3.5
Type: Hard drive
Capacity: 3TB
Brand: Seagate
