Seagate 320GB Momentus Thin SATA 3Gb/s 5400RPM 16MB 2.5" 7mm
THE WORLD'S FIRST 7MM Z-HEIGHT, 2.5 INCH FORM FACTOR DRIVE
Quicklinx: 86TFWS00 Mfr#: ST320LT012
Opens new frontiers for system designers.
Seagate® has purpose-built the Momentus Thin hard drive to meet our customers’ demand for affordable, slimmer, fully functional computing solutions. Meet your needs with 500GB, 320GB, 250GB and 160GB capacity options.
While traditional laptop hard drives offer a z-height of 9.5 mm, Momentus Thin hard drives stands apart with a z-height of just 7mm.
Smooth migration to Advanced Format.
Momentus Thin hard drives include Seagate SmartAlign technology. This innovation helps you easily get all the benefits of the new Advanced Format 4K sector standard—no utilities, no extra steps.
  • Enhanced durability
    Designed to withstand the rigors of daily use, the Seagate Momentus Thin features a shock tolerance storage of 1000 g @ 1 ms, ensuring your data remains safe even in the event of accidental drops or bumps.
  • Optimized for quiet operation
    The QuietStep technology incorporated into the Seagate Momentus Thin ensures a silent operation, making it an ideal choice for environments where noise levels are a concern.
  • High compatibility
    With its Serial ATA-300 interface and compatibility with Windows 7, the Seagate Momentus Thin offers seamless integration into most PC setups, ensuring a hassle-free upgrade or installation.
Seagate Momentus Thin ST320LT012 - hard drive - 320 GB - SATA 3Gb/s
Hard drive - internal
320 GB
2.5"
SATA 3Gb/s
Data Transfer Rate
300 MBps
Buffer Size
16 MB
Spindle Speed
5400 rpm
QuietStep, Native Command Queuing (NCQ), Ramp Load, Advanced Format technology
70 mm x 101 mm x 7 mm
92 g
Microsoft Certification
Compatible with Windows 7
320 GB
2.5"
SATA 3Gb/s
Buffer Size
16 MB
Bytes per Sector
4096
70 mm
101 mm
7 mm
92 g
Performance
Drive Transfer Rate
300 MBps (external)
Spindle Speed
5400 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Start / Stop Cycles
600,000
Expansion & Connectivity
1 x SATA 3 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5"
60 °C
Shock Tolerance
350 g @ 2ms (operating) / 1000 g @ 1ms (non-operating)
