Seagate 3.5" 1TB SATA2 Video 3.5 Hard Drive 5900RPM 64MB Cache
Quicklinx: BLRCWS00 Mfr#: ST1000VM002
Seagate Pipeline HD hard drives deliver the reliability, capacity and performance needed by the next generation of high-definition DVRs and media centers.
Seagate Pipeline HD drives deliver unprecedented levels of acoustic, power and vibration performance for high-definition DVRs. With the ability to support up to 12 simultaneous streams and operate at drive case temperatures of up to 75°C, they provide reliable storage that enables consumers to take full advantage of premium services like video on demand. Seagate Pipeline HD drives are the gold standard for high-definition performance and capacity.
  • Optimized compatibility
    Designed specifically for PC use, this Seagate Pipeline HD hard drive seamlessly integrates with your system, providing a reliable storage solution without the hassle of compatibility issues.
  • Robust environmental adaptability
    With an operating temperature range from 0°C to 75°C, this hard drive is built to withstand diverse environmental conditions, ensuring consistent performance whether in a cool office or a hot data center.
Seagate Pipeline HD ST1000VM002 - hard drive - 1 TB - SATA 6Gb/s
Hard drive - internal
1 TB
3.5" x 1/4H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
Spindle Speed
5900 rpm
Native Command Queuing (NCQ)
10.2 cm x 14.7 cm x 2 cm
415 g
Microsoft Certification
Compatible with Windows 7
3-year warranty
1 TB
3.5" x 1/4H
SATA 6Gb/s
Buffer Size
64 MB
10.2 cm
14.7 cm
2 cm
415 g
Performance
Drive Transfer Rate
600 MBps (external)
Spindle Speed
5900 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5" x 1/4H
RoHS
Limited warranty - 3 years
75 °C
5 - 95% (non-condensing)
Shock Tolerance
80 g @ 2ms (operating) / 350 g @ 2ms (non-operating)
