Smart. Safe. Secure. Seagate provides drives specifically for surveillance storage for years. SkyHawk is built to keep systems in the field longer and reduce the need for post-deployment support.
                Enhanced reliabilityBuilt to withstand continuous operation, the Seagate SkyHawk Surveillance HDD offers a high MTBF of 1,000,000 hours, ensuring long-term reliability and peace of mind for critical surveillance systems.
                Optimized for surveillanceFeaturing ImagePerfect firmware, this hard drive minimizes dropped frames and downtime with a workload rating 3 times that of a desktop drive, making it ideal for surveillance systems.
                Efficient power managementWith power consumption modes ranging from 0.5 Watt in sleep/standby to 5.6 Watt during active operation, this hard drive balances performance with energy efficiency, reducing the overall cost of ownership.
- Seagate SkyHawk Surveillance HDD ST2000VX008 - hard drive - 2 TB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 2 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 64 MB
- Spindle Speed
- 5900 rpm
- 24x7 availability, ImagePerfect firmware
- 101.85 mm x 146.99 mm x 26.11 mm
- 610 g
- 3-year warranty
- Capacity
- 2 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Buffer Size
- 64 MB
- 101.85 mm
- 146.99 mm
- 26.11 mm
- 610 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 180 MBps
- Spindle Speed
- 5900 rpm
Reliability
- MTBF
- 1,000,000 hours
- 24x7 Operation
- Non-Recoverable Errors
- 1 per 10^14
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 3.5"
- Power Consumption
- 1.8 Watt (start) , 5.6 Watt (active) , 4 Watt (idle) , 0.5 Watt (sleep) , 0.5 Watt (standby)
- Limited warranty - 3 years
- 0 °C
- 70 °C
