For everything NAS, there's IronWolf. Always on and always working, IronWolf is enhanced with AgileArray technology for optimal reliability and system agility. Multi-user technology and extreme workload rates allow IronWolf to perform and scale up with your enterprise.
A thriving small business needs storage that can thrive with it. IronWolf is optimized for NAS in multi-RAID environments that not only handle the vibration, but also handle the high user workload rate in a high data traffic network.
Tough, ready, scalable
For everything NAS, there's IronWolf. Always on and always working, IronWolf is enhanced with AgileArray technology for optimal reliability and system agility. Multi-user technology and extreme workload rates allow IronWolf to perform and scale up with your enterprise. -
Grow your business NAS
A thriving small business needs storage that can thrive with it. IronWolf is optimized for NAS in multi-RAID environments that not only handle the vibration, but also handle the high user workload rate in a high data traffic network. -
AgileArray and the Power of IronWolf for your NAS
IronWolf is built with AgileArray. NAS-optimized for the best NAS experience possible, AgileArray focuses on drive balance, RAID optimization and power management. -
Dominate the media
Build your home NAS media empire with IronWolf HDDs. IronWolf leads the class in storage capacity with drives as large as 10 TB, and the performance needed to run high definition content with your NAS. Store thousands of full-length HD films and even more photographs on your private server.
- Seagate IronWolf Pro ST2000NE0025 - hard drive - 2 TB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 2 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 128 MB
- Spindle Speed
- 7200 rpm
- Hot-Plug Support, 24x7 availability, rotation vibration sensor, AgileArray
- 101.85 mm x 146.99 mm x 26.11 mm
- 550 g
- 5-year warranty
- Bundled with
- Seagate Rescue Data Recovery
- Capacity
- 2 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Buffer Size
- 128 MB
- Bytes per Sector
- 512
- 101.85 mm
- 146.99 mm
- 26.11 mm
- 550 g
- Bundled with
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 195 MBps
- Average Latency
- 4.16 ms
- Spindle Speed
- 7200 rpm
Reliability
- MTBF
- 1,200,000 hours
- 24x7 Operation
- Non-Recoverable Errors
- 1 per 10^15
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 3.5"
- Power Consumption
- 4.5 Watt (idle) , 7.5 Watt (active) , 0.8 Watt (standby) , 0.8 Watt (sleep)
- ICES-003 Class B, NMB-3 Class B
- Limited warranty - 5 years , Insurance - data recovery - 2 years
- 5 °C
- 60 °C
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Shock Tolerance (operating)
- 70 g @ 2 ms
- Shock Tolerance (non-operating)
- 300 g @ 2 ms
- Vibration Tolerance (non-operating)
- 5 g @ 10-500 Hz
