Play faster, work smarter. FireCuda drives meld the advanced SSD technology with a standard hard drive for a compact blend of capacity and faster speeds. FireCuda blends SSD technology and a standard HDD, resulting in performance similar to an SSD but with all the capacity you expect from an HDD. It's the perfect upgrade for gamers, creative professionals and PC enthusiasts. With a spacious storage, FireCuda makes deleting games and files - to free up disk space - a thing of the past. It is perfect for gamers and creative professionals who want it all, now.
Fast, big, durable
Play faster, work smarter. FireCuda drives meld the advanced SSD technology with a standard hard drive for a compact blend of capacity and faster speeds. -
Ferocious performance
FireCuda blends SSD technology and a standard HDD, resulting in performance similar to an SSD but with all the capacity you expect from an HDD. It's the perfect upgrade for gamers, creative professionals and PC enthusiasts. -
Richer gaming experience
FireCuda SSHD delivers faster load speeds for non-stop performance and play. Save time with a drive that boots in seconds, not minutes. Get in the game significantly faster than traditional hard drives. -
Superior storage
With a spacious storage, FireCuda makes deleting games and files - to free up disk space - a thing of the past. It is perfect for gamers and creative professionals who want it all, now. -
Efficient power savings
Potentially lower your overall costs and increase your capabilities with the FireCuda. FireCuda 2.5-inch SSHD is performance-tuned to draw less power. Reducing power consumption and heat generation it helps increase system performance and improve durability, especially when playing games and running multiple applications.
- Seagate FireCuda ST2000LX001 - hybrid hard drive - 2 TB - SATA 6Gb/s
- Hybrid hard drive - internal
- Capacity
- 2 TB
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- QuietStep, Halogen Free, Adaptive Memory technology
- 69.85 mm x 100.35 mm x 7 mm
- 96 g
- 5-year warranty
- Capacity
- 2 TB
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Bytes per Sector
- 4096
- 69.85 mm
- 100.35 mm
- 7 mm
- 96 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 140 MBps
Reliability
- Non-Recoverable Errors
- 1 per 10^14
- Load / Unload Cycles
- 600,000
Expansion & Connectivity
- SATA 6 Gb/s
- Compatible Bay
- 2.5"
- Power Consumption
- 1.7 Watt (read) , 1.8 Watt (write) , 0.5 Watt (idle)
- RoHS
- Limited warranty - 5 years
- 0 °C
- 60 °C
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Shock Tolerance (operating)
- 400 g @ 2 ms
- Shock Tolerance (non-operating)
- 1000 g @ 1 ms
