Seagate Expansion desktop drive, add-on storage for your PC
The Seagate® Expansion desktop drive provides extra storage for your ever-growing collection of files. Instantly add space for more files, consolidate all of your files to a single location, or free up space on your computer's internal drive to help improve performance. Setup is straightforward; simply plug in the included power supply and USB cable, and you are ready to go. It is automatically recognized by the Windows® operating system, so there is no software to install and nothing to configure. Saving files is easy too--just drag-and-drop.
Take advantage of the fast data transfer speeds with the USB 3.0 interface by connecting to a SuperSpeed USB 3.0 port. USB 3.0 is backwards compatible with USB 2.0 for additional system compatibility.
- Windows® 7, Windows Vista®, Windows XP SP3 (32-bit and 64-bit) operating system
- SuperSpeed USB 3.0 port (required for USB 3.0 transfer speeds or backwards compatible with USB 2.0 ports at USB 2.0 transfer speeds)1
Inside the Box
- Seagate Expansion drive
- 4 foot USB 3.0 cable
- 2-year limited warranty (EMEA)
- Quick start guide
The easy-to-use storage solution
The Expansion external hard drive can be installed easily by plugging in two cords. Start saving your digital files to this hard drive within seconds of removing it from the box. -
Adds storage capacity instantly
Digital photos, video and music files can tax your computer's storage, causing performance to decline as its internal hard drive fills to capacity. -
Can be installed in seconds
Seagate Expansion External hard drive features make it easy to start using this drive within seconds of removing it from the box.
- Seagate Expansion Desktop STBV2000200 - hard drive - 2 TB - USB 3.0
- Hard drive - external (desktop)
- Capacity
- 2 TB
- Interface
- USB 3.0
- Power Source
- Included AC adapter
- Enclosure Colour
- Black
- 118 mm x 179.5 mm x 37.5 mm
- 940 g
- Localisation
- EMEA
- 2-year warranty
- Capacity
- 2 TB
- Interface
- USB 3.0
- 118 mm
- 179.5 mm
- 37.5 mm
- 940 g
Expansion & Connectivity
- 1 x USB 3.0
- Power Source
- OS Required
- Microsoft Windows XP (32/64 bits) SP3, Microsoft Windows Vista / 7 / 8
- Cables Included
- 1 x USB 3.0 cable - 1.2 m
- Enclosure Colour
- Black
- Localisation
- EMEA
- Limited warranty - 2 years
