Get an HDD for all your PC needs bring you outstanding excellence in personal computing.
                VersatileGet an HDD for all your PC needs bring you outstanding excellence in personal computing.
                Advanced powerAdvanced power helps save energy without sacrificing performance.
- Seagate Barracuda ST2000DM008 - hard drive - 2 TB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 2 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 256 MB
- Spindle Speed
- 7200 rpm
- Native Command Queuing (NCQ), Halogen Free, Seagate OptiCache technology, Seagate AcuTrac technology, Seagate SmartAlign technology, Hot-Plug Support, Worldwide Name (WWN), TGMR recording technology, S.M.A.R.T.
- 101.6 mm x 146.99 mm x 20.17 mm
- 415 g
- 2-year warranty
- Capacity
- 2 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Buffer Size
- 256 MB
- Bytes per Sector
- 4096
- 101.6 mm
- 146.99 mm
- 20.17 mm
- 415 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 210 MBps
- Seek Time
- 8.5 ms (average)
- Track-to-Track Seek Time
- 1 ms
- Average Latency
- 4.16 ms
- Spindle Speed
- 7200 rpm
Reliability
- Non-Recoverable Errors
- 1 per 10^14
- Load / Unload Cycles
- 300,000
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 3.5"
- RoHS
- Limited warranty - 2 years
- 0 °C
- 60 °C
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- 5 - 95% (non-condensing)
- Shock Tolerance (operating)
- 80 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 350 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.5 g @ 22-350 Hz
- Vibration Tolerance (non-operating)
- 3 g @ 22-350 Hz
